Question about Belkin Basic Wireless Router
Works for a day then shuts off
My router will work for about a day then it shuts off..It get hot,what's wrong with it?
    Novelist:
  • 108 Answers
If it is getting hot, just make sure that it is placed in a well ventilated area. A router should not get very hot due to its operation.
Alternative steps:
1) Open the router page by typing 192.168.2.1 in the address bar of internet explorer.
2) On the bottom-left corner, click on self-healing and disable this feature
3) On the far-left, click on "Channel & SSID" under "Wireless" > Turn OFF the QoS feature on this page.
Observe the connection and make sure that the connection shouldn't drop due to heating up of router.
I would strongly recommend that the router and modem is switched OFF when not in use.
If you still seem to have the problem, contact 1-800-2235546 and ask for replacement as it has a 2 years hardware warranty and lifetime phone support warranty.
Revert for any further clarifications.
Thanks & regards,
Arvind
Posted on Jul 09, 2010
Need help with Bosch hydropower 13h tankless hot water system
when you turn on the hot water tap there is a pressure switch in the line that sends a signal to a gas solenoid to pass the gas and at the same time to the pizo to start the flame
I would have that pressure switched checked as it may be sticking ( internal contamination) or have dirty corroded points
as gas is involved I would suggest a gas technician do the jib
when you turn off the tap, that pressure switch is shut off so the gas is turned off at the solenoid and the pizo is stopped.
May 21, 2015 | Bosch Water Heaters
I get intermittent wi_fi service. Sometimes it works two days in a row and for the next few days it keeps searching and searching for my Wi-Fi connection. I shut airport off and plug in the hard wire and...
You may have people close to you with wireless using the same channels and interfering with your router. Try changing channels in the router settings or move the router to a different location.
Sep 18, 2012 | Cisco Lynksys Dual Band Wireless N Gigabit...
Can't get internet to work with dir-615 router for more than a day or two at a time
If you have more than one device hooked up to the router, when the problem occurs try pinging another device. If you are able to then the router is working fine and most likely the modem is flaky and needs to be replaced. The modem supplies the internet connection, the router just applies NAT so that more than one device and use your public IP address. If this turns out to be the issue make sure you contact your ISP for any special instructions. For instances Comcast requires the MAC address located on the bottom or back of the modem in order for your connection to work, other ISP use proxy settings. Century Link has no requirements.
Jan 22, 2012 | D-Link DIR-615 Wireless Router
Linksys E3000 Wireless Connectivity Problems the router is excessively hot too. Can connect with ethernet cables I have cable mode and the cable company sees my lan card I can get internet connected via...
That excessive hot temperature of your router is not a good sign, it means that something is wrong with it and the problem is hardware base and in just a few more days or weeks the router will eventually stop working even when using ethernet cable.
The best thing to do here if the router is still new and under warranty is to have it replace from store or from where you purchased it.
Mar 04, 2011 | Linksys E3000 Wireless Router
Joined comcast 3 days ago. My laptops (wireless cards) would never work. Now have unplugged router for it caused my 2 desktops to shut down. How do I make this router work? Comcast doesn't have a clue
can you give some more informations - like are you able to go online with router hardwired and what lights on router are on // ? and are you able to see the wireless network (any ) when you search for wireless on your laptop . ?
Oct 01, 2010 | NetGear WGR614 Wireless Router
Whirlpool gold gh5184xpb Everything seems to be working but it doesn't heat. If you use the buttons for popcorn or dinner plate, an error message F3H appears. Recently got a wireless router in our home...
its very unlikley to be the wireless router,,,
things like this just happen,,,i would say the magnatron had gust given up the ghost, thats the part that gets the food hot,,,safest bet is have it looked at but get ready to buy a new unit as its likley to be the cheepest way out
please dont go poking about inside your microwave,,
it will still have 1000's of volts inside it,,, these volts will kill you if you tuch the wrong part,,be warned!!!
Jun 05, 2010 | Whirlpool GH7155XHS Microwave Oven
Not getting ethernet connection from the router to the modem
Please check your router's power is working or not.
if your router's power adaptor is OK the possibilty is your router's motherboard is faulty.
need to go service center.
Mar 30, 2010 | Zonet ZSR1134WE Wireless Router
My laptop shows full signal but refuses to connect to the router. The wireless phone rang two days ago and knocked me offline on wireless. Can someone please help? Nobody else's wireless device works...
It sounds like the wireless setup in the router may have gotten corrupted. From the wired PC, using a browser type 192.168.2.1 to access the router. It will ask you for a password. The default is to leave it blank. If you've set one, you'll need to give it the one you set. That'll get you into the router. Check the wireless setup. Everything else should be ok, or you wouldn't be able to access the internet from your wired PC.
If you can't find anything wrong, you can try rebooting the router and the modem. Shut both down as well as your wired PC. Wait 30 seconds. Boot the modem, the router and the PC at 30 second intervals.
Jun 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
BL-C30A Can not access via web after a few days
Your cameras are losing conncetivity because of the air link being compromised this could be due to unintentional jamming (blocking of the wifi signal)or Resetting of the beacon (beacons can be set to broadcast at intervals) They are needed for the wifi devices to know that they are still a part of the network. These are more then likely your problem
Sep 24, 2007 | Panasonic BL-C30A Network Camera
Belkin Basic Wireless Router Logo
196 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
