Question about Kitchen Ranges
I have noticed that there is a little wetness on the floor after my load of washing clothes is done. It is towards the right back corner, at first it was just a little round circle of wetness now ti is a little bit more but it does not seem to happen with every load. It is a whirlpool top loader about 4 years old. Please help, I am going on vacation and worried something will happen when I am gone.
  • loc629 Jul 09, 2010
    Thank you so much, I was just worried it could be a major problem. So you think that is waht it cuold be. The fact that I have been using the maching while it leaks can that be a problem?
    Thanks Again for your help. My washer is in the basement, but I will definitely shut the water off by the machine before I leave. Thank you very much!!
  • Kitchen Ranges Master
  • 6,826 Answers
Oh, the tube for output of water from the machine could have a clamp that is loose. Also, if you are going on vacation, shut the water off to your washer so that the tubes won't break while you are gone. This is recommended by the manufacturers, and could save you a lot of money in water lost if the tubes would unfortunately burst.
Have a nice vacation.
Posted on Jul 09, 2010
  • Duane Wong
    Duane Wong Jul 09, 2010
    It will probably be fine as long as you turn the water off and don't use it for the duration of your being away.
  • Duane Wong
    If the leak were bigger and the washer was on a floor that was above something sensitive, then I would be more concerned. Most people put their washers in the basement where it won't do too much damage to a cement floor and there is a drain nearby.
First I noticed that the clothes after washing them were still a little too wet---then a month later, a loud noise ensued. no leaking no smoke and still wet clothes, also no shaking.
Sounds as if the belt may have a flat spot in it. They run about 24 dollars online. Take
a look at it by unplugging it and having someone hold the machine back at an angle.
There should be an obvious area of excessive wear somewhere on the belt.
Also check the idler pulley (wheel) for excessive play or binding. Hope this helps.
Mar 10, 2011 | Speed Queen AWS75NW Top Load Washer
My samsung front load washer wont stay in the spin cycle and bounces the timer keeps resetting its self back to ten and it takes for ever to do a load half the time it never reaches the full spin cycle and...
there could be few problems, and your right, floor could be the problem.
Try holding it by the corners when begining a cycle, so you can see where is the problem, which corner is not leveld
(The testing: when begining a cycle puch down one corner at the time and only one, when machine apper's stable diagonaly from that corner is the problem, you need it higher)
Also there could be a problem with iner springs (that are holding the drum), one may come lose, check that if you can
Oct 31, 2009 | Samsung Washing Machines
Suds in the floor...
are you using he detergent,,,or low suddsing detergent,,,i believe your putting to much detergent,,and not the right detergent,,,to test run a load with no soap,,and see if you get water on the floor..onthejob
Dec 29, 2008 | GE WBVH6240F Front Load Washer
GE front load washer
Remove the front lower panel (3 screws on lower lip - lay on floor to see). Panel come right off. there is a round "dial" to the front housing. Put down a bath towel on the floor and unscrew dial - then pull it out.
Aug 15, 2008 | GE Energy Star WCVH6260F Front Load Washer
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Apr 25, 2008 | LG WM-2277HW Front Load Washer
Excessive shaking during spin
hi thanks for the question is the washer on the main floor on a wooden floor if it is re level washer next pull washer towards you tipping towards you lift from floor a few inches and let drop to floor this will re level the back legs thanks the appliance doc
Mar 17, 2008 | GE Profile WPRE6100G Top Load Washer
Washing machine works, but wont do spin cycle- clothes sopping wet but clean
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Mar 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud squeaky Noise
this is not 100% diagnosis as can't listen to noise but fault may be bearing lip seal disintegrating which is a serious fault and if im right then bearing will shortly go as well. reason it is noisy during start is that seal is dry and gets wet when full of water
Apr 18, 2007 | LG WM-2277HW Front Load Washer
Water leaking from wash machine
It is probably a seal that is on or near the bottom of the tub. Dirt and grim wears at this seal over time. The leak is slow so it is hard to visually see.
Dec 09, 2006 | Frigidaire MWS939Z Top Load Washer
Kitchen Ranges Logo
47 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
