Question about Coleman Powermate Premium Plus 6250W Portable Generator
My generator is poping or firing back through the carb. What is the problem.
    President:
  • Coleman Master
  • 1,388 Answers
Generally this is caused by leaking intake valve. The valves could be out of adjustment, weak or broken valve spring or bent valve. If the generator was not used for a while, rust could have formed on the seat. Easy to check compression and compare to factory specs. Or loosen valve adjustment a bit and run engine with upper cylinder lube in fuel or squirt directly into carb. If it does not improve may be time for valve grind. Not too difficult. Good luck on your repair
Posted on Jul 10, 2010
YG650DE Yamaha generator. Fires up perfectly, then shuts down after a minute. Will fire up again, run about 1 minute then shut down. Same thing over and over. changed out gas and oil. Help please
Since most generators are seldom used, gas left in the carburetor gunks up and stops up the passages.
Take lots of pix of the assembly. Pull the carb, remove the bowl and spray carb cleaner in all the holes you see. Don't let it back spray into your eyes. Wear safety glasses. Some holes/orifices may need to have a soft wire passed thru them.
Next time you store your generator, drain the gas, run the generator til all the gas is out of the carb. If you can get to the bowl w/o removing the carb, pull the bowl and spray the bowl and underside of the carb w/carb cleaner and reassemble.
Sep 11, 2017 | Yamaha Electrical Supplies
Chevy 350 poping out of carb
If nothing has been done to carb or engine easy things it could be are carb needs rebuilt or adjusted,timing may need adjusted,plugs may need changed firing order could be wrong or possibly a worn lob on the cam shaft
Oct 11, 2015 | Cars & Trucks
25hp kohler engine the engine is poping and back firing
Timing has moved. Remove flywheel and see if you sheared the key. Timing is set by flywheel placement. Clean governor and the carb while you're at it.
May 26, 2015 | Garden
Generator back firing from inlet manafold
Your symptoms are from running lean. Foam air filters put debris in carb jets. Check all the carb passageways and jets. Always start with a new plug.
Nov 29, 2013 | Electrical Supplies
Poping while trying to start
Over time carbon deposits build inside the engine including the valves, seats and spark plug. Easy to change plugs however not so easy to clean carbon. There are products at auto parts store that you can pour into carb and add to fuel that can help to eliminate deposits. Leaking valves can cause poping noise, backfire etc. Easy fix is to try using products mentiond above then new plugs and add several gallons of premium fuel to increase the octane level. If the engine does not run however suspect old fuel or water in fuel bowel. Try spraying carb cleaner into carb little at a time to keep running. If the engine runs with carb cleaner, suspect fuel/carb/pump problem. Good luck
Oct 20, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
20 hp runs but is poping and running poorly one plug gets fouled other is ok could this be carb related? i have spark on both plugs
Not likely carb because both cylinders would act the same; not likely coil because both cylinders fire together, however could be wire/boot from coil, plug or low compression/valve adjustment. Premium fuel works miracles on small engines; try a couple of gallons, it will increase horsepower. Check compression and compare to good cylinder, if close, suspect plug or boot. If compression low, hope that valve adjustment will normalize. Good Luck
Sep 07, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Back fires thru carb when excellerating but lopes when u take off manual trans
do you hear a pop pop poping under heavy acceleration or just one big back fireing when first accelerating? it could be an intake valve pop pop poping,and electrical,on the big bafireing under lite to med load. A cracked,or worn cap and rotor,weak coil wire,dirty carbruator,faulty accelerator pump in carb bad vacumn advance !slow ignition timing. BAD points and condenser if equiped on older model with carb.
Sep 01, 2010 | Jeep Cherokee Cars & Trucks
Trys to fire now and then . It has a weak spark.
start with a daignostic test, simplely remove the airfilter, tiurn the switch on,spray a one second spray of starting fluid into the carb, pull the engine, if it fires then you have identified the problem, bad gas and dirty carb. If it does not fire on starting fluid then you have either a compression problem like a stuck valve or an ignition problem, calling for a new ignition module. Good luck, white back if I can help more?Jim
Dec 19, 2009 | Coleman Powermate Powermate 5000W...
I need the setting for my coleman power generator 10hp tecumseh
If you have fire coming out of the carb, then your intake valve is stuck open. Take the head off, and as you turn the engine, tap on the valve with a plastic screwdriver handle to make it go in, then turn it more to push it back out. If you need to put a light coating of oil on it, so be it. Keep doing this until it's freed up, then put it back together.
Jun 08, 2009 | Coleman Powermate Powermate 5000W...
My lincoln welder/generator with onan engine will only run for a short time when it shuts down. It doesn't matter if in use or not, either welding or generating. It is getting fuel and the coil has been...
my 20 hp onan won't start it's getting fuel and spark. it will fire and almost run then stop. and a few times poped back through the carb. it has good compresson .and the flywheel key has been replaced
Apr 13, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
249 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
