Question about GE Profile JTP56 Electric Double Oven
Error code f1 - GE Profile JTP56 Electric Double Oven
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F1 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
How do I fix my oven door keeps locking up and F1 comes up and starts beeping
Here is a detailed description of this error code. Your control can be rebuilt by fixyourboard.com. See article here on Kenmore/GE F1 Error Code: Oven Failure After Self Clean and F1 Errors
Aug 27, 2015 | Ovens
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
F13 code
Hello friend, thank you for your post!
Based off the information you have provided your question is under an "F13" error code but you also stated that it is showing you an "F1" error. I have researched both error codes for you. "F13" usually indicates error identification, which could be an issue within your control board. "F1" typically can indicate that the range has detected an issue with the runaway temperature (overheating). Both codes could be corrected with a reset, which you can do by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend contacting a professional. I hope this is helpful. -Matt
Aug 07, 2014 | Frigidaire Ovens
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
What does the error code F1 E1 mean and how can i fix it
Hi.
F1 - E1 means: EEPROM Checksum error. The EEPROM is a memory chip located in the ERC (control module). The problem is communication error with the EEPROM
Note: Applies to all F1-Ex codes except F1-E3.
Regards.
Ginko
Aug 29, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
1.
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F1 Error Code
According to the GE website, F1 usually means a problem with the keypad. You might try my solution for the F7 problem which is similar in nature. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my solution with more than 1900 folks and most report success.
Please let me know if it works for you at:
hutchipop@yahoo.com
Good Luck,
Powerman
Jul 16, 2008 | Ovens
GE Profile JTP56 Electric Double Oven Logo
112 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
