The batterys on those phones are known for defective batterys especially when you plug them up at night before you go to sleep and leave them plugged. It usually only takes 2 hours to charge so 8 hours when its already fully charged is going to kill the life of the battery.
Sounds like you may have left your radio in direct sunlight fot too long. first thing to check is the batterys- they could have been "cooked". A possiblelsAo also possible that the batterys sweated inside thier compartment so the contacts would need to be cleaned. for this, use cotton swabs dipped in 90 percent rubbing alcahol.
Laptops that I have worked on do not need the laptop to be switched on to charge the battery. There maybe a LED indicator on the laptop to indicate that the battery is charging when the power adapter is connected.
If the light is on on the charger you likely need a new battery or if its the kind that is not replaceable battery the gun it no good. Batterys olny last so long and if there left in the cold they olny last 40 %of what they should so never leave them in unheated areas. These companys will give you the drill they make there money off the batterys Ihave many and use them for my business
batterys generaly consist of 4 cells if one cell goes bad usually the battery will function but not at top preformance some batterys are sealed by the manufacture so you cant service them others have a plastic removable square plug which plugs two of the 4 cells very carefully remove one of the plastic covers from the battery remember sulferic acid burns a lot.... if one of the cells in the battery is dry add water or if you are a mechanic you can purchase acid in a plastic container at any auto parts suppier if the battery doesnt put out at least twelve volts i recomend replacing it servicing batterys should be handled with extreme care any they range from 40 to 140 dollars buying a new one may be the safest ansewer
I have the same problem. One day my truck worked great and then the next day it just wont start. I replaced the 12v battery but still no start. I also have a 2005 chevy silverado hybrid.
switch off take batterys out of remote plug back in after 30 secs insert batterys try again should sort your prob mate send me your codes to check also kiki
Batterys in laptops are now Lithium Ion batterys (li-ion) these batteries do not have a memory effect so it does not matter if you leave the laptop plugged in or not, you will not affect the performance
If it beeps three times then the line space lights blink
1 the batterys are installed incorectly
2 no batterys are installed
3 the batterys are weak or dead
