Question about Microwave Ovens
I have a Kenmore electric Range model #790.9654 and the stop burners, oven, and broiler are not heating up. The clock works and the only burner that does work is the center burner which is a warmer. The oven light also works.
    President:
  • 1,099 Answers
There are a number of reasons why you may find that your oven doesn't heat up, and troubleshooting oven heating elements is not too complicated, so you should be able to manage this in a few hours. When you are trying to decide what is the cause of your oven not heating up properly, you should be able to identify the different problems, and also understand how to repair the oven without too much difficulty. If you find a lot of problems, then you may need to provide a different solution, for example replacing the heating element and fittings completely.
Heating Element is BrokenThis is perhaps the most common cause of the oven not heating up. The element inside the oven will not become hot if the electrical connections are damaged, or if the element itself is not working. The heating element can be removed and replaced easily, and this is perhaps a very good idea if you have any problems with the heating system of your oven. Test the heating element by firing up the oven with the door open, and your hand close to the front of the element. You should be able to feel it warming up, so if it doesn't, take of the screws which hold it in place, and then unplug the connections. You can take the heating element to a store and they should be able to replace the part for you.
Grill Doesn't Warm UpIf you are having problems with one part of your oven, for example the grill, then your element maybe damaged, or it may be the connection to the heating system. The grill's electrical components can be reached from the back, removing the access panel and then twisting out the wires. You should be able to locate a wire which is not properly connected to the rest of the system, or you may need to replace the entire grill part. If the latter is the case, then you will have to take your own to an electrician, who will be able to take off the grill and fit a new one.
Entire Oven Doesn't WorkIf your problem is with the whole oven system, including grill, main oven and hobs, then the problem might lie in the electrical system which is connected to your oven. Unplug the cable, and try putting it into another socket. You should also check the plug to make sure that none of the wires are loose in the connections, and the fuse is still functioning. You can also remove and replace the power cable completely. If this does not work, then you may have a major problem with the electrical connections inside the oven, and it may be best to leave it completely, and call in an expert, or have the oven replaced with a new one.
Other problems include a fuse blown inside the oven itself, and wires which need soldering back together. Check all of the wires together, and make sure that there are no loose parts.
hope this works...
Posted on Jul 09, 2010
Do you know what the average electric cooktop lifespan is? We have a Kenmore that is 9 years old and working fine. However, we are in the midst of a renovation and are wondering if it wouldn't be wise to...
The life span of the range depends on it's use or abuse.... Common issues are burners and the connections that the burner plugs into. These are not hard to change out.... There is nothing that can make the stove useless, if you keep after it. Newer units do a better job of retaining the heat within the unit, oven wise....Which is nice.
A gas range is certainly nicer, so they say. It is faster, but has one odd issue: if you boil water over, you can put out the flame and have raw gas running in. Most work this way, expensive units have thermal sensors that would turn off the gas flow in flame out condition....
My wife loves her gas range....
Mar 08, 2011 | Microwave Ovens
The burners will not light. I hear a clicking noise but no sparks. oven and broiler works fine
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Jan 16, 2011 | Microwave Ovens
Our ignitor is stuck on on our Kenmore 790 range. It's the large "power burner" in the front. How can we stop the clicking?
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Jan 04, 2011 | Kenmore Microwave Ovens
I have a GE Range model number JBP72DM2BB. The front main burner stopped heating up. Is there a quick fix to this?
I ASSUME THIS IS ELECTRIC. REPLACEMENT BURNERS CAN BE BOUGHT AT MOST MAJOR HARWARE STORES. THEY ARE EASY TO REMOVE AND REPLACE. THEY SIMPLY PULL OUT, LIFT THE BURNER AND PULL TOWARDS THE OUTSIDE OF THE RANGE AND IT SHOULD SLIP RIGHT OUT, THE REPLCEMENT SLIPS RIGHT BACK IN.
Nov 26, 2010 | Microwave Ovens
Oven will not light
Go to partselect.com and look for a ignitor.
When on this site... you will be asked to put in you model # which you will find in the drawer below oven.
This is a very simple project which should be about half hour to replace.
No electrical to turn off, no gas to turn off. Just a screwdriver, and the job is finished
Jul 29, 2010 | Kenmore 80412 Microwave Oven
Whirlpool Range RF315PXDW. Electric range. Top burners and oven will not turn on. Clock on top of stove and oven light turn on. Oven preheat timer operates but heating elements in oven do not turn on....
It sounds like you are missing part of your input voltage.
I would take a voltage reading at the receptacle and confirm you are reading 220-240VAC. Some homes have the 220 service receptacles wired up with two 120 volt breakers to make up your 220 service. If your home is configured this way, you may have one of the breakers tripped. Or, the receptacle itself may be bad. If you confirm you have the correct voltage at the receptacle, your power cord may be bad.
The reason the clock and display will still appear to work is because the clock only uses 110-120VAC and is tapped off the source voltage. The surface burners and the oven heating elements, however, require the full 220 service.
If you are confused by this explanation, please post back and let me know. Hopefully, this is a problem that will not require any parts or a service call. If the power cord is bad, you can purchase a replacement at any hardware store. I hope this information is helpful.
Dec 19, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
