Question about Sony VPL-HS20 Multimedia Projector
Vpl-hs20 sony video projector please clean air filter appeared on screen...i replaced it and i don't know how to get the message off the screen...can u advise???
4 Suggested Answers
Marrie
  • 563 Answers
SOURCE: VPL-HS20 issues...who's got the right answers!
Hi Malibu Stevi
To get the best time out of your Projector and your lamp , you should take in your Projector at least twice a year for a service.
If you want to clean out the filters , simply take a vacuum cleaner and vacuum the dust out.
As for the fan , this could be as a result of dust , but I would suggest you have it checked out by a Sony Service Provider as fan malfunction is the biggest cause of lamps blowing.
Also try not to run the Projector for short periods at a time as this simply eats away on your lamp. Rather leave it running for longer periods a Projector's lamp is similar to the lamp's you use in your house - switching on and off all the time makes the lamp's fillament weak - Take my word on this , I've had please using the Projector to watch a odd movie now and then and they only get 500 - 1000 hours on their lamps. And then I've had clients who use their Projectors as TV's and they got 10 000 - 15000 hours on their lamps.
Hope this is of help and thanks for using Fixya !
Posted on May 06, 2008
jell587
  • 447 Answers
SOURCE: DO YOU KNOW WHERE I CAN PURCHASE A SONY VPL HS20
Do can download it for free from here (in PDF format).
Posted on Mar 31, 2009
BlackOnyx
  • 102 Answers
SOURCE: sony vpl-hs20 cineza projector- reset lamp counter
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Posted on Feb 06, 2010
My Sony VPLHS-20 has original bulb, now just shut off 50 mins into the SuperBowl. No fault light, in fact, no lights showing on the display at all. Bulb has around 1800 hours. I waited 10 minute, red...
Pretty sure it the bulb as most are rated at 2000 hours; but also check for full air flow - clean filters etc. Bulbs can run hotter as they age, so air flow is more important, because there is an inside heat sensor that will shut the machine down.
Feb 09, 2011 | Sony VPL-HS20 Multimedia Projector
Powering up
the projector is quite good and may not have any internal defect
may the bulb has really burnrd out......
try a new bulb if it works or not
Oct 15, 2008 | Sony VPL-HS20 Multimedia Projector
Sony vpl-hs20 cineza projector- reset lamp counter
Jul 19, 2009 | Sony VPL-HS20 Multimedia Projector
Clean filter for sony projector
A Sony technical support professional is available to provide fastanswers to all projector questions. Call (800) 883-6817 and choose options 2 then 6.
Jun 26, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
VPL-HS20 shuts down in the middle of a movie
There is a heat sensor cutting down the power. The sensor is located on the upper side between lamp and fan and is monitoring the air temperatur. I don't know what is causing the sensor to switch - excessive heat or simply age or ... . Anyway un screwed this sensor and my problem disappeared.
Possibly a stronger fan would solve the problem too.
Jun 26, 2008 | Sony VPL-HS20 Multimedia Projector
I know this post is 3yrs old, but wanted to add a couple things. I have the VPL-HS20, you can take the filter out and blow it out with air can duster every so often. I bought a new one and they are over $30.00.. Also buy the correct bulb LMP-H180 3000hrs if you replace it. You can clean the front lens protector, Remove slide tab, hold top and bottom of lens cover assembly and give a firm 1/4 twist clockwise, then pull out. You can clean it with glass cleaner cloth.
May 04, 2008 | Sony VPL-HS20 Multimedia Projector
SWITCHES TO MEMORY STICK
If you unplug the unit for a few hours prior to use this will fix the problem .
Apr 12, 2008 | Sony VPL-HS20 Multimedia Projector
Sony VPL-HS20 Multimedia Projector Logo
261 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
