Question about Nokia N70 Cellular Phone
N 70 Call Recorder`
I tried so many call recorder softwares but not satisfied
i need these options
No Beep
Auto save
show contact names not numbers
Please Help Me
  • Anonymous Jul 05, 2008
    i call
  • Anonymous Dec 05, 2008
    help me
    President:
  • 1,017 Answers
This one is perfect for N70:
Smart Call Manager, for Symbian OS, v5.23.15 from www.eltima.com
"Confucius he say: House without toilet is uncanny."
Posted on Apr 20, 2008
How do I put phone numbers on the sim card
To copy names and numbers to the
SIM card
1 Select Menu > Contacts.
2 Scroll to New contact and select
Options > Advanced > Copy to SIM.
3 Select an option.
When you copy all contacts from your
phone to the SIM card, all existing SIM
card information is replaced.
To automatically save names and
phone numbers on the SIM card
Options > Advanced > Auto save on
SIM.
3 Select an option.
To save contacts on a memory card
Options > Advanced > Back up to m.
card.
SIM contacts
SIM contacts can contain names and
numbers only. They are saved on the
SIM card.
Sep 02, 2014 | Sony Ericsson T707 Cell Phone
Sound recorder
Please check all of the settings options under the Control Panel - Sound.
Mar 09, 2014 | Toshiba Computers & Internet
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Recover deleted files from cenix vr-p3490
You can recover deleted files with asoftech data recovery software. get the software from link below
Audio Recorder Recovery Software
Please be noted that your voice recorder memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
You may check out this memory card recovery tutorial also
Apr 22, 2010 | Panasonic RR-QR150 Digital Voice Recorder
No voice recognition
You must have already set up and trained a user with the Dragon NaturallySpeaking software prior to transcription. Make sure that the Digital Voice Editor (DVE) software is not opened prior to starting these steps.
Open the Dragon NaturallySpeaking software.
The Dragon Bar window opens. From the Dragon Bar menu, click the Sound button.
From the Sound button, select the Transcribe Recording menu item.
The Transcribe a Recording dialog box opens.
Click the large square button to the left to start the DVE software.
The Digital Voice Editor window opens.
NOTE: If the file you want to transcribe is still on the Integrated Chip (IC) recorder (which will be reflected on the left side in the IC Recorder window), you will need to connect the IC recorder to the computer using the supplied USB cable, or transfer the file to the computer.
Select the item you want to transcribe from the PC window on the right side.
Click on File from the tool bar.
Select the Voice Recognition menu item.
The Converting.. Dialog box opens.
The Transcription Options dialog box opens.
Click the Transcribe button to continue.
The Transcribing window and Dragon Pad window opens.
The text is displayed while the transcription is in process.
NOTE: Once the transcription is complete, it may be necessary to make grammar, word, punctuation, and formatting adjustments.
To save the text file, click on File from the tool bar.
Select the Save As. Menu item.
The Save As dialog box opens.
Browse to the folder location to which you want to save the text file and double-click on that folder.
The folder you chose should now be showing in the Save in drop-down box near the top.
Type in the desired File name in the File name drop-down box towards the bottom and then select the document type.
Click the Save button.
Click the X (close) button in the upper-right corner to close the Dragon Pad window.
Click the X (close) button in the upper-right corner to close the Digital Voice Editor software.
Feb 10, 2010 | Sony ICDSX68 Digital Voice Recorder
I deleted seven voice files off my Olympus DS-2300 and need them back! Can they be restored or retrieved?
Yes, those voice recordings can be recovered provided not overwritten(if you keep taken more records, then possible). The best way is to try some audio recovery software. Here are some for your option. Both programs can also recover videos and photos.
Photo Audio Video Recovery Software (for Windows)
Mac Photo Audio Video Recovery Software (for Mac OS X)
Note: Before your audios are recovered, do not attempt to save more files.
Nov 10, 2009 | Olympus DS-2300 Digital Voice Recorder
Sony Ericsson Satio not displaying contact name when receiving a text, only displaying their numbe, despite me having their name & number stored in my contacts list. When making and receiving call, and...
there may be promlem in ur contact setting so try this.....
go to contact option then open setting
there may be many options like contact view e.tc
u choose in these option "name and number"
Nov 10, 2009 | Sony Ericsson Satio Cell Phone
Lost the installation cd
You will all need to call Olympus to have the software be emailed to you as it is not available for download from their website. The telephone number to call is 888-553-4448 option 5 and then option 2 for Digital Voice Recorders
Nov 10, 2008 | Olympus VN-2100PC Digital Voice Recorder
Download device
The easiest way to correct that is to uninstall and reinstall the DSS player software. Before you go so far though, open DSS Player and go to Tools then Options and make sure the Auto download option is checked. If the option is checked but not working just uninstall and reinstall to reset the drive associations.
Jun 05, 2008 | Olympus DS-2300 Digital Voice Recorder
Nokia N70 Cellular Phone Logo
110 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
