Question about LG LRBC22544 Bottom Freezer Refrigerator
I owm a LG Model # LFX 25960sw and its given me a er dh what should i do?
  • 60 Answers
SOURCE: LG Refrigerator
That stands for a defrost heater problem. Usually it's the defrost detect circuit that has a blown thermal fuse.
Posted on Dec 20, 2007
  • 27 Answers
SOURCE: where is this fuse located on the LG refrigerator is displaying a ER DH code error
Hi. You have an Error Defrost Heater. Its taking too long for the heater sensor to open the circuit during defrost. You normally replace the heater, heater sensor and circuit board(motherboard) located on the back of the refrigerator in this situation. Check your mollex plugs and make sure they are connected tightly at the evaporator coil area. Sometimes they come loose. I reccommend replacing the heater and heater sensor located top right on the evaporator coil. This should take care of the problem. Need parts see me on ebay as user, themackshack. Good luck, Mack
Posted on Jan 06, 2008
  • 489 Answers
SOURCE: LG LRSC26923TT freezer not freezing error display
You have a defrost problem that requires a service call from a qualified LG technician.
Posted on Apr 29, 2008
  • 1122 Answers
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
Posted on Jul 07, 2008
SOURCE: Error message on LG Refrigerator
The message is ERROR ICE FAN. You can order a new one from LG for around $65 and if you know someone handy they can probably put it in by just eyeballing the old one. WARNING>>>>this must be someone with common sense and some degree of problem solving skills as it does not come with the fan blades and that must be switched. This is a common problem with this model and usually the ice fan goes out in about 12-20 months. Use your owners manual to figure out how to get the door off and access the fan. Also, Lg employees are confused and may try to tell you there is just one fan......they did tell me that!
The ER IF is part # 46811B1029E---The ER FF (freezer fan) is part # 4681JK1004E and only a skilled repairman can modify them to be interchanged.
Posted on Aug 31, 2009
LG Ref/Frzr LFX 31925st ERROR CODE ER 1F NEED MEANING AND FIX
A F1 or 1F error code on the refrigerator's display indicates a problem with ice blower fan or ice maker motor.
search LG error 1f and u will find lots of info
Dec 09, 2016 | LG Refrigerators
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Message ER DH continues to pop up on the door. If
ER =ambient temp sensor failure
DH= defrost heater
Defrost heater, temperature fuse short
circuit, unplugged connector(indicated
4 hour later after trouble)
You is gonna have defrost problemas!
Feb 24, 2010 | LG LRSC-26922 Side by Side Refrigerator
Have a LG 3 door bottom freezer with error code Er dH. Was told by tech support to unplug for 10 mins. If this fails unit needs service. Is this correct?
dh means defrost problem.replace defrost control and element,behind freezer panel.dont forget to unplug fridge before you work on it
Nov 17, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
LG code ER DH, Defrost Heater or Thermistor?
Check for current flow through the defrost heater. If no current then replace the heater. If heater is OK check thermistor for correct operation. From service manual chart (their words not mine): ER DH is Poor defrosting. Indicates: Even though it is passed 1 hour since then
Defrosting , if Defrosting
sensor is not over 8°
Remarks: Temperature fuse Disconnection,Heater
disconnection, DRAIN Jam,
Poor Relay for Heater
Aug 11, 2009 | LG LFX25960ST Stainless Steel French Door...
Dec 07, 2008 | LG LFX25960 Bottom Freezer French Door...
Error Message: Er dH
The error codes are listed in the service manual (p. 32) at the address below:
LFX25960 Service Manual
"Er dH" seems to be a defroster issue.
Aug 14, 2008 | LG LFX25960 Bottom Freezer French Door...
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
Jul 07, 2008 | LG LRFC25750 Refrigerator French Door
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Jun 13, 2008 | Refrigerators
Error Code
dh error code is a defrost problem. You will need to call a qualified LG technician to diagnose and repair this problem.
Nov 25, 2007 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG LRBC22544 Bottom Freezer Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
