It's wery simple actually.Just take out the paper cassetes,open the right door and you remove the roller with one move,just push the plastic pin and pull the rooler of the axe
Ensure that the "BYPASS" button on the control panel is not illuminated. Make sure the "Standard Feeding " is selected in the driver. Try cleaning the lower separation roller. Make sure the separation roller is pressing up against the feed rollers. If the roller set is worn, order a replacement set of rollers (Google: Canon 9080 Exchange roller kit)
I think this is rubber roller problem. Obviously, the scanner cannot find out which is the last page. If the paper available is less, the roller is not pulling the last few sheets.
S. Mohan
The exchange roller kit has all the tires that pick up the paper in the kit (feed, separation, and pick up tires). I think the other tire you are talking about is just one tire not the set. Also check to see a switch on the scanner that is used for single feed or multiple feed. If its on single feed it will multi feed all the time. You can clean the tire with rubbing alcohol too, to see if your double feeding goes away.
Check for a switch on the scanner that is made to feed single pages or multiple pages. If it is on single page it can multi jam all the time. As far as the rollers go there is a pick up roller, separation roller, and a feed roller. You can clean them with rubbing alcohol to see if its indeed the tires that are bad. The exchange kit has all three tires in it that are user replaceable.
