I have a Vulcan 135 litre model 641135 and is ketteling with the hot water after it's turn off. How can I fix the problem? mike.
3 Suggested Answers
  • 1015 Answers
SOURCE: i had a new 315
I would check breaker to make sure it is not tripped. Next check owners manual for location of reset and make sure it is set. If you have a volt meter check to see that you have proper power supply. You should have had hot water long before now. After you have checked above items and if you don't have any sucess I would call your installer. Hope this helps. Thanks
Posted on Nov 24, 2010
  • 3074 Answers
SOURCE: i want to buy the
you can try eBay:
http://shop.ebay.com/i.html?_nkw=hot+water+element.&_sacat=0&_odkw=gas+hot+water+element.&_osacat=0&_trksid=p3286.c0.m270.l1313
here is another site:
http://www.hawkinscommercial.com/parts.shtml?gclid=COyph-H-jKkCFUMUKgodr0qaqg
Posted on May 29, 2011
HOW TO REPLACE THEROSTATE
Twin element indicates you have 220-240Volt electric water heater.
Brand unknown.
135 liter implies European, or Canadian water heater.
Not sure if this water heater uses ordinary thermostat.
Copy following links for resources:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Sep 04, 2012 | Rheem Water Heaters
A cuboida water tank is 6m long , 5m wide and 4.5m deep. How many L of water can it hold
A tank that big is as big as an average garage but here is the volume:
6m x 5m x 4m is 60 decimeters by 50 decimeters by 45 decimeters whitch is 35000 cubic decimeters which is 35000 litres.
Unless you mean 60 cm x 50 cm x 45 cm which equals 135 litres.
Oct 11, 2011 | Vacuums
I want to buy the Vulcan gas hot water 135 liter element. Please give the address in Melbourne Thank you
you can try eBay:
May 29, 2011 | Heating & Cooling
This was bought last xmas and has not worked since the late spring. when you turn the power button on it start to make the noise like its gonna brew then nothing comes out and it turns it self off.
it sounds like its full of scale,,,get yourself some kettel cleaner mix it up in warm water in a jug first, then fill the coffee maker with it and try to make a brew with no coffee in it,,,when you do this catch the kettel cleaner in a jug as you will need to run it through a fuw times to clean the brewer out,,only after its flowing good do you stop running kettel cleaner,,after that flush it out with lot and lots of fresh clean water ,,,before you make or drink from it!!!! or it may clean you out as well?
Nov 28, 2010 | Keurig Elite B40 Coffee Maker
I had a new 315 litre vulcan hot water system installed today and the power was turned on about 4:00pm and it is now 11:45pm .. how long will it take to heat up before i can have a shower ? the water still...
Nov 24, 2010 | Heating & Cooling
I have a 135 litre, 10 year old Rheen mains pressu...
usually on the hot water piping, It starts to rust closed faster than the cold side, due to electrolosis. What you r discribing are the first signs of this happening. only solution is to replace the effected pipes..
May 20, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Too much water draining from Vulcan Electric H/W relief valve.
Dear Julie. Do you have an expansion tank installed? If so it is probably waterlogged. If you come home shower etc. use lots hot water then go to bed or leave the cold water in your tank heats and expands as it heats. In the old days a toilet ballcock valve would relieve this pressure but modern toilets with diaphragm valves wont so the pt valve relieves pressure. Installing an expansion tank on the cold water line near the heater will absorb the extra water & stop the pt valve from activating.
Dec 29, 2009 | Water Heaters
Running out of hot water with Vulcan Freeloader 300
hi i need help with mi Vulcan 300 hot water main gas pressure...
our kitchen tap got broken and we turn off our main water pressure in front off our house and now our hot water gas not working ....please help
thank you ...
Sep 24, 2009 | Water Heaters
How to drain the rheem 135 litre tank
1. turn off the electrical power first.
2. attach a garden hose to the hose bib attachement on the bottom of the water tank and run the hose outside to allow the water to drain out by gravity.
3. Turn the valve that is on the inlet of the water heater. Now that the power is off, you can drain the tank.
4. open the drain valve where the hose has been attached.
5. To release the pressure, you can open a hot water faucet in your kitchen. This will allow the water to drain out easier.
Sep 12, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
