Question about Stanley Bostitch Coil Framing Nailer
My bostitch n63cp coil framing nailer blows air continuously near the trigger and does not shoot the nail. What is wrong and how can I fix it?
Replace the trigger valve assembly. Part TVA6. It takes just a few minutes. The part will include a pin punchout tool, you supply the hammer.
Posted on Apr 21, 2011
How do i rebuild my bostitch n80 frameing nailer
Bostitch nailers are simple to rebuild. Bostitch company was sold to Dewalt so parts are now easier to obtain from local Dewalt service center. Use Ork11 oring kit and tva6 trigger valve. These parts are also available on ebay. Good luck or your nailing projects.
Sep 18, 2014 | Stanley Bostitch N80CB Coil Framing Nailer
The framing nailer blows air out the exhaust,and will not fire a nail when I pull tre trigger
take of clylinder head when off there is a large button make sure its fre should work like a door bell switch grease slightly and put together again
Aug 28, 2011 | Stanley Bostitch Coil Framing Nailer
How do you set up the bostitch coil framing nailer for contact nailing?
Bostitch nailers have two triggers available. Black trigger is rapid fire while the gray is single shot. Both triggers are usefull depending on type of work. Most people say that there is a degree of accuracy with single shot allowing for better placement of nail. If speed is your goal then use the black trigger to bump fire. More information and parts can be found at www.bostitch.com , look for "Support" tab, then "service / parts " find your model number from the pull-down list and search for the manual and parts list for needs. Good luck on your projects.
Jun 30, 2010 | Stanley Air Tools & Compressors
Have a stanley bostitch framing nailer. Nails
Normally, yes- depends on how old the nailer is. But first, let's ask: are you getting at least 90 psi of pressure to the rig?
If so, you may adjust the nailer with an allen wrench, or with a thumbwheel, both of which are located near the firing mechanism.
IMPORTANT: before you mess with it, be sure no pressure is left in the unit, otherwise you may be on here asking how to extract a framing nail from your skull while your hand is attached!
Nov 25, 2009 | Stanley Air Tools & Compressors
My bostitch rn46 seems to double or triple shoot nails frequently. Am I not using the tool properly or could there be a mechanical problem with the tool?
if u are right nails for gun,then make sure when u put coil in and feed in front of firing pin the nails are straight with pin and connecting wires are not bent causing nails to fall out of alingnment.
Oct 02, 2009 | Stanley Factory Reconditioned Bostitch...
Air blows thru the trigger on both my finish nailer and staple gu
there is an o ring in the trigger valve referred to as a Purple o ring that is probably split. If you can find a air tool center that has them you will save a lot of money versus replacing the trigger valve. Let me know what you are going to do and I will help you with the removal of the valve.
Sep 30, 2009 | Stanley Bostitch Coil Framing Nailer
Roofing nailer blows air does not nail
Piston probably stuck,you can try some air tool oil and pull trigger to let it flow in and let it sit a bit upside down. try that,good luck!
Jul 16, 2009 | Stanley Bostitch Coil Framing Nailer
Stanley Bostitch Coil Framing nailer blows head off of nail?
Make sure that when you run with one gun that your psi is between 90-110. You may need a kit. Is it an RN45 or 46? Go to Stanley Bostitch online and look up parts and schematics. Kits should only be about 15-20 dollars, easy to put in, and come with instructions. Lemme know. Please rate me
May 31, 2009 | Stanley Bostitch Coil Framing Nailer
Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Jan 05, 2009 | Stanley Bostitch Coil Framing Nailer
Stanley Bostitch Coil Framing Nailer Logo
405 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
