Question about Whirlpool Refrigerators
Drips of water appearing from vent area at top of refridgeration section next to lightbulb
  • 999 Answers
Check your defrost drain for blockage and look under the freezer floor for an ice dam.
Eric
Posted on Jul 09, 2010
Water in refridgerator
Have a look inside fridge compartment (especially the "roof", if it's a top-mount freezer) & see if you can see any ice build-up (look inside vents that allow cold air into fridge from freezer section. Also, if top-mount freezer, look inside the freezer compartment for ice build-up on "floor", inside vents, or on back wall. These symptoms, combined with water dripping from lots of the "roof" of fridge section (in a top-mount freezer model), can mean several different problems, so best to re-post with more info/symptoms included.
If there's no ice build-up (& the dividing area between fridge & freezer sections isn't particularly cold, which otherwise might indicate hidden ice build-up), it can be as simple as a plugged or obstructed drain tube, which is VERY COMMON. Easiest solution for this latter problem is to use a flexible plastic tube (think similar type as attached to aquarium air pumps), stuff it into drain hole, and blow on the other end. Sometimes you have to blow quite hard to clear an obstruction or complete blockage. If you can't clear the drain tube, it's likely a different problem. Again, a re-post with more info/symptoms will help narrow it down.
Sep 17, 2013 | Roper Refrigerators
Water is draiNung in the refridgerator
drain tube for freezer defrost plugged, you will have to remove of the inside trim but an easy fix
Sep 02, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping inside KTLA22EMSS01
Your freezer actually cools your fridge. It sounds like you have ice build up in your freezer behind the back panel. You should be able to unscrew the back wall inside your freezer. A hair dryer should help defrost or keep it open for a few and use a screwdriver to remove the build up of ice. The ice has made its way down the vent and when it hits the fridge it is above 32 degrees so it is melting. Hope this helps. I manage rental properties and have had it happen on a few occasions.
Aug 16, 2012 | KitchenAid Refrigerators
Water collecting on top shelf of refridgerator
Your defrost drain line in the freezer has stopped up. The defrost water is coming in through the air vent to the fresh food section.
Turn the unit off and use a hair dryer to defrost the drain hole located behind the freezer panel.
Jun 21, 2011 | Kenmore Top Freezer Refrigerator
Kitchen Aid KTRC22EK leak inside refridgerator
It sounds like the drain for the defrost water is pluged. You can remove the back panel inside the freezer(ice maker will have to coe out first) and access the drain in the rear center of the freezer. Check the drain. It can be defrsted with a hair dryer(shut off the referigerator first) good luck, snugglepants
Nov 03, 2009 | KitchenAid KTRS22EL Top Freezer...
Refridgerator drips water from the cold air vent.
if your freezer is on top,you most likely have an overflowing defrost drain. there is a drain that starts in the freezer and continues down to the drip pan. start at the top and work your way down.
Jul 26, 2009 | Whirlpool ET4WSKXS Top Freezer...
Water drips from evaporator fan channel Frigidaire FRT17G4B
It sounds as if this is a top mounted refrigerator. (freezer on top) If this is the case, check to see if you need to defrost the drain. You could also have a problem with the door seals. Remember the air coming out of the vent is freezer temp minus a few degrees. It could be that the moisture is condensing in that area.
Feb 01, 2009 | Frigidaire FRT17G4B Top Freezer...
GE refridgerator
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
Jan 02, 2007 | GE GTS12BBPLCC Top Freezer Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
