Question about Ricoh Aficio CL3500N Laser Printer
My printer Ricoh aficio cl3500n does not print and all the lights on. Why?
  • 903 Answers
The first step is to turn the machine off and then turn it back on. Do all the lights come right back on, or is it okay until you try to print to it?
If all the lights are on, there should be an error message appearing on the display. It might say out of paper, or out of toner, or a cover open, or it might show a code (such as "sc 501").
What is the code or error message that appears?
Posted on Jul 13, 2010
I have a Ricoh Aficio CL3500N When I print a vertical page there are thin black lines going down the left side of the page. What causes it?? And what can I do??
Hi, thin black lines are most likely (but not definitely) caused by something in the black PCU (photoconductor unit), either the drum or the charger. Replacing the black PCU will likely get rid of your lines. The Ricoh code for a black PCU if you don't already have one is 402448.
Jan 29, 2011 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N Laser Printer How do I clear the print que from the printer?
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jul 01, 2010 | Ricoh Aficio CL3500N Laser Printer
Can ricoh aficio cl3500n use glossy paper that is
Ricoh recommends heavier paper be run from the
bypass tray 16lb to 53 lbs are the recommended weights
Sep 25, 2009 | Ricoh Aficio CL3500N Laser Printer
We have a Ricoh Aficio CL3500N. We are getting a
Never clean or touch the Transfer Roller (spongey rooler) unless your using a dry cloth or vaccum as last measure.
Usually the transfer roller sits on a drum/pcu specific to that color. If you can tell which color is sitting on to of the roller replace that drum/pcu.
Jul 15, 2009 | Ricoh Aficio CL3500N Laser Printer
Cant install to Vista pc Ricoh CL3500N
Try downloding the RCPS driver.
-Carl, please let me know if this helps.
Feb 04, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
http://www.websitetoolbox.com/mb/copierquestions
Jan 19, 2009 | Ricoh Aficio CL3500N Laser Printer
Stops Printing Entire Page After Around 50 sheets
First, check the text in your records for odd characters. It is sometimes possible in data entry to hit a ctrl-"letter" combination that embeds printer codes in your text and these are invisible in many cases to the application. The easiest way is to break up your print job to sections of records and see if a particular record consistently causes an error.
If your sure however that the printer is the problem...
Then I would check the RAM. The printer has 128MB upgradable to 512MB. Normally you can pull the ram and run jobs on the internal memory, but in this case you would need to swap it out.
Jun 05, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio cl3500N
the extra page comes from the page setup..
the jamming comes from odd paper textures, or not 'riffling' the paper before placing it inside the tray
check your user manual for more on both of these issues.
May 01, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
346 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
