Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
Philips 55 i have philpihs 55" hdtv, sometimes i can see small tint green color on screen..? can u tell what's the problem for this and how to fix it... will wait for ur reply, Thanking you in advance.. Sam..
This tint of green may just be one of the chips going out(There are three chips: red, green, and blue.). You can buy these for about $80-$100, but sometimes they are hard to come by(depends on where you are). You may also try to readjust the screen from the back. If you look in the back if you remov the wood that covers the back of your TV, there should be about 6 little knobs you are able to turn(Focus, red, green, blue, tilt, or reset...i think).try that...
It also depends on however long you have had this TV. It this time: you may also want to buy new resistors, for some of them may just blow out right after you fix the chip.(they are about 50 cents-1 dollar).
Hope that helps
Posted on Jun 25, 2008
There is a green tint from the middle to bottom of the screen and it has green letters above the regular letters as if it where a double word. what is wrong with this tv and how do i fix it?
See attached photos: It sounds like a convergence problem and is common on these sets.
It can be a do it yourself repair but it depends on your skill levels.
Let me know and I will be happy to help you.
SD TECH
Jan 14, 2012 | Philips 55PW9363 55" Rear Projection...
My RCA 55 inch DLP HDTV needs the color fixed. It keeps showing purple and green on the screen
color wheel is getting ready to fail which is causing the color wheel to spin slower which cause the index speed to be off so the tints will be messed up.
Aug 22, 2011 | RCA Televison & Video
The image appears to have excessive yellow tint. and there are no images coming thru the blue projector
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Philips 55PW9363 55" Rear Projection...
The colour keeps going to more blue and the screen is fuzzy?
you should be able to align your projectors through the setup menus. you will have to align two colors, usually red and green to stop the fuzziness and you should look at the tint selection in the menus for the blue color if the realignment does not fix it as well.
I could not locate the manual on the Hitachi website.
Oct 29, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Philips 60PP9202/17F Blue Problem
call the repairman back and tell him the tv isnt fixed correcctly. have him come back and finish the work he started
Jan 27, 2009 | Philips 60PP9202 60" Rear Projection...
Yellow tints on screen and color is faded.......
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 22, 2009 | Philips 55PW9363 55" Rear Projection...
Green color screen
your hdtv cables are wrong color match them to the input on tv
Nov 09, 2008 | Philips 55PW9363 55" Rear Projection...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Multiple pictures
Try www.magnavoxhelp.com - They have a fix listed on their site.
Jun 01, 2008 | Philips 55PP9363 55" Rear Projection...
Green tint screen
Took mine to a repair shop and they said there was an issue with the line something? circuit board. Quoted me 225 parts 450 parts+labor. Mine was a red tinted screen.
Jan 17, 2007 | Philips 55PP9701 55" Rear Projection...
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
