Question about JVC GR-DV1 Camcorder
JVC DV1 recording screen horizontal roll error
I have a JVC DV1 since new (15 yrs) a long time back a problem began with the recording screen picture sliding out of frame to the right, and back in from the left, rolling slowly and continuously. I sent it under warrantee and JVC fixed it, but after a few months it ocurred again. I put it away in for several years. I assume the problem is a faulty chip somewhere. The quality of the video capture was always very high. JVC (Australia) took a long time before and still didn't get it right. Is it worth fixing again, or should I just throw it out?
  • JVC Master
  • 5,412 Answers
For equipment of that age, fixing it would cost more than replacing it.
Posted on May 02, 2017
  • 507 Answers
The eye piece works fine?
  • 236 Answers
SOURCE: jvc 32" has grouping of thin white lines at top of picture extending 4" down from top of frame
It sounds like you have a bad capacitor in the vertical circuit. The circuit needs to be checked out by a technician. Stargazer
Posted on Aug 20, 2007
  • 13 Answers
SOURCE: JVC Camcoder GR-DX77 has no Picture in Record Mode
Definitely, don't use Sony miniDV tapes! The fault occured because of rough handling of the mechanism during cassete insert or from dropping the camera.A guide arm inside the mechanism is deformed and the mechanism can be changed in whole for this.Contact a JVC authorized centre.The price for this can be half the price of a new camera. After all, it's your fault. This is a good camera if you know haw to handle/ use it!!!
Posted on Sep 15, 2007
  • 5 Answers
I cant find a solution but causes may be :
1. Did you remove the LENSE CAP ?
2. PRobably there is a small switch that tells the camera that LENSE CAP is on or something dunno
About that recording problem
1. LCD Broken?
2. Other technical issues ...
Im not proffesional or anything :P Wish you luck with better people at this D: .
Posted on Feb 20, 2009
  • 586 Answers
SOURCE: Bands or lines on screen during playback
Hi tlaufer ,
              According to the symptom this problem is related to the VIDEO HEAD, As you earlier try to clean the head but no results, Please open the cassette compartment of your camera (as when you insert the cassette in it) for 30 mins (remains open cassette compartment) Actueally some time due to moisture head get durt.
After 30 mins insert the cassette and play it. Hope it will start work again fine.
      But if no result from the said procedure then there must be a damadge of point of the head, in this condition you have to replace the VIDEO HEAD assembly.
Thanks for using fixya.
Posted on May 23, 2009
SOURCE: JVC 32", 11 years old. flashes from picture to
after 4 or 5 yrs (depending on usuage ) in some TVs on mainboard & CRT tube's circuit board at some soldering joints cracks develops ... then due to loose contact TV behaves as you have described ........ when you are hitting that lightly on its side then these cracks at soldering joints are getting connected temporarly & for few seconds or minutes you are getting normal picture ....... so solution is most of the soldering joints on mainboard & on CRT circuit board has to be resoldered ....... only good tv service engineer can do this without shorting joints or damaging components..... so in your place contact few TV service engineers & ask them how much they will charge for resoldering joints on mainboard & crt tube's circuit board ......
Posted on Sep 05, 2011
Vizio E470i_A0 shutting off after loosing horizontal frame sync
It could be several things but I'd start with a main board, the fact its shutting off kind of drives me away from Tcon as that shouldn't shut the set down if there was an issue there, it also could be power supply, you could test the voltages from the board once it starts giving issues and if some are off then change the power board.
Dec 10, 2017 | Vizio Televison & Video
I bought a JVC GR-SXM250u Super VHS camcorder a couple days ago and the picture has horizontal lines flashing in and out so I can't see in the display both in pause mode and in record mode. He said he...
you may have a faulty camera there,,,or the vcr tape may be faulty and has spred some of the tape on the recording head try running a cleaning tape through the vcr first to clean the heads,,then use a new tape (not the old tape!) to try that out,, if its cleans the head up throw away the old tape so you never put it back in this vcr
Sep 04, 2010 | JVC GRD250 MiniDV Digital Camcorder
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
JVC picture turns into a single line in middle of screen.
This is caused due to random falure of vertical scan circuits. It generally is caused by dried out capacitors or bad driver IC. Unfortunately it will get worse. If you fail to turn the TV off quickly you will burn a permenant horizontal line on the tube. Trip to the repair shop I am afraid.
Nov 30, 2009 | Televison & Video
Dark screen- No images- some shadows horizontally
If you get a blank LCD, dimly lightened by a whitish back light, then the LCD display eis either faulty, badly connected, or the ribbon connector to LCD is defective.
The camera must be taken apart, ribbon cable tested, and eventually replaced and adjusted.
If all contacts on ribbon cable return continuity (cable is fine), then LCD is faulty, and must be replaced.
Althought the job is not too difficult, an user without experience may damage the camera in attempting this repair.
My first suggestion is always taking the unit to a camera shop.
Aug 23, 2008 | JVC GR-D90U Camcorder
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
Toshiba dvd Video player & vcr SD-V396SU2
Thanks. We have replaced the unit with a JVC but will give the SP/SLP a try just to see.
Nov 29, 2007 | Toshiba SD-V394 DVD Player/VCR
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
Split screen and blurred vertical lines in view finder and LCD
Elakkis, I am sorry you are having a problem with your JVC camcorder. Your camera more than likely has a defective CCD imager which is being replaced by JVC factory service at no charge because of a problem with the Sony CCD chip being used. Call JVC and arrange to send the camera to them. Hope this helps you! Joe Weibel Custom Electronics (
Feb 11, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
JVC GR-DV1 Camcorder Logo
71 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
