Question about GPS
How do I reset my trip data info. - GPS
    President:
  • 1,561 Answers
Hold the GPS firmly at arm level. This will help prevent striking the wrong keys as the keypad is very small.
Locate the Light key. It can be identified by the icon of a light bulb on a green background.
Press the Light key for approximately three to four seconds. This will initiate the quick power down sequence. When the sequence begins, release the Light key.
Wait approximately one minute for the GPS random on-board memory (ROM) to fully discharge.
Press the green Light key to reactivate the GPS. Wait for the welcome screen.
Take care.
Posted on Jul 09, 2010
I have a 2010 Chevy impala LS instrument cluster and it has a 20 pin plug I'm trying to figure out which wire's on the back of the cluster are for the speed sensor, rpm, gas, and temp wires.
Boy your way off base . All the gauges are inputs from the ECM - engine computer . The VSS - vehicle speed sensor , ETC - engine coolant temp sensor , sending unit in the fuel tank , All this sensors input the engine computer . The PCM then sends this info on the GMLAN serial data bus ,communications network . The Instrument cluster has a microprocessor inside that translates this info an controls the gauges. You probably have an instrument cluster problem or a communication network problem . Your best bet is to take your vehicle to the dealer or some other qualified repair shop. Need to have it checked for DTC'S - diagnostic trouble codes.
Indicators and Warning Messages
Refer to Indicator/Warning Message Description and Operation.
Engine Coolant Temperature Gage
The instrument panel cluster (IPC) displays the engine coolant temperature as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the engine coolant temperature. The IPC receives the coolant temperature information via serial data message from the body control module (BCM). The engine coolant temperature gage defaults to 60?°C (140?°F) or below if:
The ECM detects a malfunction in the engine coolant temperature sensor circuit.
The IPC detects a loss of serial data communications with the ECM.
The IPC detects a loss of serial data communications with the BCM.
Fuel Gage
The instrument panel cluster (IPC) displays the fuel level as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the fuel level percent. The body control module (BCM) sends the fuel level information from the ECM to the IPC via a serial data message indicating the fuel level percent. The fuel gage defaults to empty if:
The ECM detects a malfunction in the fuel level sensor circuit.
When the fuel level is less than a pre-determined value, the low fuel indicator illuminates in the IPC.
Odometer
The vehicle odometer is calculated and stored electronically in the instrument panel cluster (IPC). The IPC contains a season odometer and trip odometer A or B. Momentarily press the trip/fuel button in order to toggle between the season odometer and the trip odometer. Press the set/reset button for greater than 0.25 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The IPC displays the vehicle mileage and trip mileage as determined by the engine control module (ECM). The IPC calculates the mileage based on the serial data vehicle speed information from the ECM. The odometer will display 'error' if an internal IPC memory failure is detected. The odometer displays either miles or kilometers and can be set through the customization menu in the driver information center (DIC).
PRNDL Display
The instrument panel cluster (IPC) displays the selected gear position as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the gear position. The PRNDL display blanks if:
The ECM detects a malfunction in the transmission range switch circuit.
The IPC detects a loss of serial data communications with the body control module (BCM).
Speedometer
The instrument panel cluster (IPC) displays the vehicle speed as determined by the engine control module (ECM). The IPC calculates the mileage based on serial data vehicle speed information from the ECM. The IPC receives vehicle speed information from the body control module (BCM) via a serial data message. The speedometer defaults to 0 km/h (0 mph) if the IPC detects a loss of serial data communications with the ECM or BCM.
Tachometer
The instrument panel cluster (IPC) displays the engine speed as determined by the engine control module (ECM). The IPC receives a serial data message from the ECM indicating the engine speed. The IPC receives the engine speed information from the body control module (BCM) via a serial data message. The tachometer will default to 0 RPM if:
The ECM detects a malfunction in the engine speed sensor circuit.
How to Diagnose Controller Area Network CAN Suggest you read up on C.A.N.
May 14, 2016 | Cars & Trucks
Tip
Cadillac service light 1989-01
Eldorado
2000-01
Turn the ignition to ON. Press the TRIP button on the driver information center (DIC) switch to view various menu choices and stop on OIL LIFE REMAINING. A message will display the percentage of oil life remaining. Press and hold the RESET button on the DIC switch for at least 2 seconds. A message will display the percentage of oil life remaining as 99 percent. The engine oil life monitor is now reset. Turn the ignition OFF.
DeVille,
Eldorado
1999
To reset the service Oil Life Indicator, display the
"OIL LIFE LEFT" message by pressing the "INFORMATION SKIP" (skip info) button. Press and hold the "RESET NO" (no info reset) button until "100% OIL LIFE" is displayed.
Deville,
Seville
2000-01
Turn the ignition to ON, Press the INFO button on the driver information center (DIC) to display ENGINE OIL LIFE. Press and hold the INFO RESET button on the DIC until the display reads 100% ENGINE OIL LIFE. The engine oil life index is now reset. Turn the ignition OFF.
Deville,
Seville,
Eldorado
1997-98
Display "ENGINE OIL LIFE" by pressing the "INFO" button. Press and hold the "INFO RESET" button until the message shows 100.
All Models
except
Fleetwood
1994-97
Press the "INFORMATION" button until "OIL LIFE LEFT" is displayed. Press the "RESET" button until "100" or "0.0 OIL LIFE LEFT" is displayed.
Fleetwood
1994-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds.
All Models,
Seville,
Eldorado
1993,
1994-95,
1994-95
The automatic transaxle message can be reset through the following procedure. If "CHANGE TRANSAXLE FLUID" appears on the Information Center, press and hold the "OFF" and "REAR DEFROST" buttons until "TRANS FLUID RESET" appears.
DeVille,
Fleetwood
1991-93
When "CHANGE OIL SOON" light is illuminated, press and hold the "RESET" and "RANGE" buttons on the Fuel Data Center for 5 to 60 seconds. When the buttons are released, the light will flash four times if it has been reset. If the light comes back on for more than 5 seconds, repeat the procedure.
Allante
1989-93
When "CHANGE OIL SOON" appears on the Driver Information Center, press the "RANGE" button until "OIL LIFE INDEX" shows on display. Then press and hold "AVG SPEED" and "RESET" (or "RANGE" on late models) buttons until display shows "100".
Seville,
Eldorado
1992-93
Press "INFORMATION" button on the Driver Information Center until "OIL LIFE INDEX" is displayed. Press "STORE/RECALL" until "OIL LIFE INDEX" resets to 100.
Seville,
Eldorado
1989-91
When "CHANGE OIL SOON" or "CHANGE ENGINE OIL SOON" appears on the Driver Information Center, press "ENG-DATA" button until the "OIL LIFE INDEX" appears. Then press the "ENG-DATA" button and the "RANGE" buttons at the same time until 100 displays (about 5 seconds).
on Dec 07, 2009 | Cadillac Eldorado Cars & Trucks
I have a toyota corrolla 2004 an is showing trip A on the dashboard. Does that mean is time for a timebelt?
Trip A is the mileage you have driven since the Trip A was last reset. Trip B is the mileage you have driven since the Trip B was last reset. To reset the Trip A or Trip B mileage select either the trip a or trip b mileage, hold down the select/reset button until the mileage turns to 0.
There will be more info on this in your owners manual. If you do not have one you can take a couple of minutes to register an account on the Toyota.com website, enter your vehicle info, and you will be able to view online PDF versions of your owners manual.
Aug 31, 2011 | Toyota Corolla Cars & Trucks
I need to reset the engine oil light?
It depends if you have a Driver Info Center or not. If you do, key on, engine off, scroll up until you see "oil life" and then hold in the reset button until it resets, the reset button looks like a backwards "L" with an arrow on the bottom leg. If it does not have the Drivers Info Center, press the trip odometer button until oil life is displayed and then hold in the trip button until it resets.
Dec 14, 2009 | 2009 Saturn Outlook
My 1300 doesnt seem to calculate trip data such as time or average speed, miles, etc. stays on zero. does show max speed.
is it set in similation mode?? try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update
Dec 01, 2009 | Garmin nuvi 1300 Car GPS Receiver
I changed the oil but dont know hou to reset the change oil panel
open the panel with the trip/od and the mirror adjust. next to the trip/od you will see a rest button. turn the car off. weith your foot OFF the brake push the start button twice while holding in the reset button. the trip/od must be set to just odometer, no trip a or b. you will see the oil mileage reset on dash right in front of you. hold the button until it finishes. if you have navleave the ingition on and push INFO button, choose MAIT and reset the oil and filter to 5000 miles.
Oct 01, 2009 | 2007 Lexus GS 350 AWD Sedan
When i reset odo on my bell f20, I lost all data like an odo reset? how can I reset only my trip data? michelbib@gmail.com
I have one too, the manual is incorrect. Only hold the LEFT side for 3 seconds, and the info will reset.if you hold BOTH sides, the whole speedometer resets, making you re-enter all the info again such as weight, time wheel size, etc... ALOT of people are having this same problem.
http://www.walmart.com/catalog/allReviews.do?product_id=10400636
Just hold the LEFT side only and you will be all set.
Apr 19, 2009 | Sport & Outdoor - Others
RESETTING THE TRIP METER
Press the info button until you see Trip A or Trip B. Once you are looking at the Trip meter you want to reset, press and HOLD the info button. After 3 seconds, the dashboard will beep and the Trip meter will reset to zero.
Nov 18, 2008 | 2008 Mitsubishi Lancer GTS CVT Sedan
Stereo code
Your system just needs to be reset. The dealer or even autozone does the sevice for free. They will plug it into you car data part.
Aug 27, 2008 | Car Audio & Video
Reset maint req
Reset - step 1 turn the key to the 'on' position. using the trip meter button, toggle the lcd until 'ODO' is displayed. step 2 turn the key off. now, push and hold the trip meter button. while holding the trip meter button, turn the key to 'on'. step 3 while you continue to hold the trip meter button, you will see on the lcd disply five (5) small dashes and they will begin to 'count down' rather quickly. step 4 continue holding the trip meter button and once all the dashes have been cleared, your lcd will display six zeros (000000) - release the trip meter button now - and then the lcd will display 'ODO' and your current mileage. at this time, your 'maintenance required'/oil change light has been reset.
May 15, 2008 | 2005 Scion tC
GPS Logo
15 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
