Question about Foxconn 661FX7MI-RS (661FX7MIS) Motherboard
Flashing Bios Foxconn Motherboard 671MX awdflash reoport error: the prom file's number does not matchwith your system. The dowload file from foxcon are numbered 641F1P0x where x = 1 to 12 but no one can flash the bios ????
  • 231 Answers
SOURCE: Requared bios updated versin for foxconn 865gv chipset mother board
Hi, I run a foxconn mobo myself and yes its a great board. But dont go to the foxconn site looking for downloads. instead go to the VIA site they make the chips and you will get more sense there. If all else fails Foxconn do have a "Contact us " link on their home page. This will give you the company email address and you could request directions to the update site there, the only trouble is it could take weeks to get a response. Regards mistyman
Posted on Aug 21, 2007
Roshan89
  • 271 Answers
SOURCE: can,t overclock after update bios(foxconn p4m800p7ma)
Try clearing the CMOS (CMOS reset)...and restoring defualt bios
Posted on May 08, 2008
BFixed
  • 104 Answers
SOURCE: Bios ROM checksum error
The rom you used to flash the bios may not have been the correct one for your mobo, or it did not complete the flash entirely. Try using the usb a drive to flash it again and/or revert back to an older version.
Posted on Aug 01, 2008
  • 158 Answers
SOURCE: bios check sum error
this is a common problem wirth asus motherboards the only thing is to re set the bios to do this romove the power plug from pc wait for 30 second - 1 minute for the static to be removed from board then find the bios battery and remove this then find the jumper that says clr cymos or bios then place the jumper on the opposite two then press on button then place jumper bace to orraginal possition then place the power cord back to tower psu then reboot pc then all will be fine replace battery in the holder enter bios then hunt for all relevent thing like first boot should be hdd then cdrom then floppy drive this is only if you have got one.
to set-up bios properly please e-mail me with your motherboard details and I'll e-mail you back with a list of things you should do to get the bios back to good working order.
Posted on Aug 26, 2008
  • 111 Answers
SOURCE: I just installed 2x1gb sticks of PC400 DDR memory
the spec says that the boad supports up to 2gb ram http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000325
maybe the sticks are not 1gb each
you can try to make a bios update.
Posted on Mar 21, 2009
Foxconn 671mx series user manual pdf
Try Googling (Foxconn)(671mx)(manual) without parens.
Jul 18, 2017 | Foxconn Computers & Internet
How to flash the JetWay 939AGP-P Bios
Get this installer programs and the Bios bin file and put them onthe desktop together and open the Awdflash exe program and fallow the instructions on this site
How to update Bios
http://www.jetway.com.tw/evisn/download/update.htm
http://www.jetway.com.tw/evisn/download/bios/Awdflash.exe
Mar 16, 2011 | VIA JetWay 939AGP-P Socket 939 K8T800 Pro...
I can't get into my bios and dont have the cd.Im running windows xp pro on a foxcon lga775 via p4m800. Please help
LGA775 is a type of processor connection, which stands for Land Grid Array, this is also known as a "Socket T."
VIA P4M800 is your chipset.
I'm not sure why exactly you want to be into the BIOS (Basic Input Output System), but In order to do this you need to press one of the function keys at boot, like F2 or F6, or even the Del Key. I could tell you which key to press next time if you would supply me with the motherboard Make and Model number. Also it will tell you at the bottom the monitor when you power on, which key to press to get into the BIOS. Hope this is informative for you. Good luck.
Jan 03, 2010 | Foxconn 661FXME Motherboard
Gigabyte Motherboard wont flash bios
your bios has been corrupted.
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions.
Note: 12345678.BIN represents the name of your BIOS.
Step by Step:
1. Create a bootable floppy diskette or bootable dos cd /usb drive
2. Copy the BIOS file and flash utility to the disk
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
Remove disk and restart computer
If you found this useful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | Intel Gigabyte GA-8S648FX-RZ Socket 478...
My computer can not boot -BIOS ROM checksum error
to be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Jun 15, 2009 | EliteGroup K7VTA3 V5.0 Motherboard
Need table of LED error codes on Foxconn mobo
here you have a link to foxcon website to take his manual, there you can see about your problem
Apr 10, 2009 | Foxconn (865G7MC-ES) Motherboard
Foxcon Motherboard pinout
Hi bwalker24,
This is a pic of how to connect you're LED & switches.
f0649db.jpg Enjoy!
Mike
Jul 25, 2008 | Foxconn 661M03-G-6EL Motherboard
Startup fault
Software Error Or Corrupted windows File files
Jul 15, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Foxconn 661FX7MI-RS (661FX7MIS) Motherboard Logo
175 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
