Question about GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White
Re: Tempurature Problems
The freezer went to 69 degrees - and fridge at 82 degrees. Then went back to normal temps - Had it checked out by a local repairman and everything was okay and the temp was right on when he arrived. Late afternoon yesterday it went to 9 degrees in the freezer and 39 in the fridge part - this morning it is at -1 in freezer and 34 in fridge. Much fluctuation. Help
  • 15,935 Answers
The thermostat is likely failing intermittently, or the defrost timer could be failing.
Both parts can be tested (and should have been) by the repairman.
The defrost timer turns on and off to let the coils defrost - but if it stays off - can cause the rise in temperature. The thermostat, however, reports the temperature to the timer, so either (or both) could be to blame.
Have them tested.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 09, 2010
Fridge now constantly CYCLES ON AND OFF for 10 to 15 minutes
Perhaps calling in a refrigerator repair man so he can check the freon as that is what causes them to run alot more than normal
Jun 03, 2016 | Westinghouse Refrigerators
1 year old kitchenaid kbfs25etss01. all of a sudden the fridge temp is up to 55 degrees. i did put a bunch of water, soda and beer in the fridge tonight. is it blocking something? door seems shut.
Watch the unit for at least a hour, to see if the temps drop. You could have had the door open too long and lost a lot of air. Normally, they can recover from this, and this is nothing to worry about. I loaded my today also and my temps went up to 45, but my door way open for about 10 mins or so. Don't check the unit for at least 1 hour. Allow time for the system to recover. It should be ok. It should be able to drop temps with in a hour or a least 10 degrees.
Get back to me if you have any more question or concerns.
Good Luck, enjoy your cold beer....
Aug 17, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Side by side refrigerator stopped cooling. Temp was 55 degrees in fridge when I noticed. Vacuumed back and between coils underneath. Removed lining in freezer and melted heavy frost and ice build-up...
Sounds like the defrost timer/board may be hanging up....
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 24, 2011 | GE GSS22JFMWW Side by Side Refrigerator
Hi, I have the psc25msta side by side GE. The fridge temp will not go below 45 degrees. The Freezer section is around 0 degrees. Checked the circ fan on the fridge side by opening door and holding...
Check damper between freezer and fridge. If it's mechanical, adjust so it let's more into fridge side. If it's electrical, damper may need replacing
Nov 04, 2017 | Refrigerators
Can a refrigerator be placed in a garage that houses the electric furnace?
Hi, all fridge freezers work on ambient room temperatures, ie room temperature. Also it will depend on the classification of your fridge freezer. On a normal classification fr/free 70 degrees should be a constant maximum. On a sub normal classification room temp should not exceed 50 degrees. on a sub tropical room temp can be pretty much as warm as you like. On the rating plate inside your fridge freezer two small letters exist (N) normal. (SN) sub normal. (ST) sub tropical. Most fridges will work for a while in the wrong temp but will work too hard and pack up
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
What is normal temperature for fridge what is normal temp for freeer
for fridge it is 12 degree celcious and for freezer it is 0 degree
Sep 11, 2009 | Freezers
Dometic rm2611 not restart after cooling box normally, then warmi
I would replace the thermister and also check the gas soleniod. Don't those get weak once they get hot or warm. Hope this helps.
May 10, 2009 | Refrigerators
Vegetables in crispe are freezing
Check for blockage of the damper door which regulates airflow from the freezer into the fridge. It might have gotten some ice buildup there while the freezer door was open.
Jan 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White Logo
232 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
