Question about Acer Aspire 4520-5582 Notebook
No sound if audio is set to realtek digital output
When
  • 9 more comments
  • raj kavi Apr 22, 2008
    usb mass storage device not working my laptop
  • sanjeeb2k007 Jul 05, 2008
    no sound comes when set to digital out put
  • Machinima Jul 17, 2008
    My Realtek Digital Output thing is not working (like the sound is'nt working) because i was doing some stuff and i think somehow i accidently turned it off.. how do i turn it back on (its enabled..)
  • Jonathan Copone
    Jonathan Copone Jul 23, 2008
    I have an Acer Aspire 4520 notebook, the os is xp. everything was working. That is until winantivrus. I finally had to reinstall xp but now I have any sound. have installed all the updates and drivers i could find, nothing works. The bluetooth audio is installed and says it is working, but still no sound. the specs say it has a realtek ac 97 sound card, I have installed the drivers still no sound
  • Anonymous Aug 18, 2008
    Same for me.
    Fujitsu-Siemens Amilo XI1526 with Realtek sound card.
    It worked before a recent Windows update.
  • ednlaidz_072 Nov 21, 2008
    no sound
  • dheliong Nov 24, 2008
    i have the same problem, no sound comes out but if a jack is plug in there is sounds...
  • Anonymous Dec 31, 2008
    No sound out for external speakers at all on either Acer portable (9422WSMi)
  • maal31 Jan 02, 2009
    I have not sound when i watch a clip.E-mail:maal31@mail.ru
  • Anonymous Jan 16, 2009
    cannot hear any music...
  • Anonymous Feb 12, 2009
    no souund at all
THe realtek Digital Output will only output sound if you have an optical cable attached. this allows you to connect your laptop a audio receiver via an optical cable. this is why you get no sound when it is set to digital output.
Posted on Feb 18, 2009
?!? what kinda best solution is that? there's nothing here!
Posted on Aug 25, 2008
He is right.
There are 2 kind of SPDIF.One "electrical" - you can use and connect mini jack to coaxial cable and secound one optical. In this cas you need optical mini jack to to Toslink.
Posted on Feb 05, 2010
Lkk
Posted on Jul 04, 2008
3 Suggested Answers
SOURCE: how to use realtek digital out put
Your drivers may need updated.
1: Right click on My computer > and then click on Properties button.
2: And then go in Hardware tag
3: Their you can find the device manager button click on that
4: At that place you will see the all drivers which are installed and also those which are not installed properly.
5: If your sound driver is not installed properly then you can see a yellow caution sign on his icon. Double click on that.
After click go on driver tag and click on update driver.
And after doing all these steps, the computer automatically ask from you to search drivers from the Internet.
I had the same problem and this worked. Hope it helps.
Posted on Sep 30, 2008
babes_ganda0
  • 381 Answers
SOURCE: realtek digital output no sound
hi..if you have a mother board installer try update the driver sound but 1st remove the old driver from your PC/unit..good luck..good day...^_^
Posted on Jun 10, 2009
How to reset settings on realtek hd audio manager
Hello
OK, all you need to do is to open the Manager from the start tray, once the manager is opened, Click on the speaker tab, and then on the Sound effect tab. You should see something like this now.
Now just click on the reset tabs, this should then reset the manager to it's default settings.
Please let me know if this was helpful. Also,, let me know if you need any further assistance.
Kind regards
Andrea
Sep 08, 2010 | Computers & Internet
Just bought HDMI cable to be used on dv9700 got the picture on my tv, but no sound go to sound option but not able to see any HDMI sound output I got only 2 options on my sounds: 1. Speaker 2....
We might need to change the audio settings from Sound and Audio device properties window.
Open Control and double click on Sounds and Audio devices to access the window.
Change the audio output from analog to digital.
Make sure that HDMI audio is enabled in the sound device.
If the source device menu has adjustment for PCM frequency, set the frequency to 96khz or less than that.
Sep 01, 2010 | HP Pavilion dv9000z Notebook
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
No audio on pc problem
Check the Sound and Audio settings to make sure that the proper output device has been selected. Go to your Control Panel then Sound and Audio Devices, then the Audio tab. In that tab make sure that Default Sound Playback is set your sound card.
Sep 25, 2009 | Computers & Internet
Acer ax1700-u3793 doesn't display an hdmi sound output option
try to check if the audio cable(jack) is properly connected to your device or speaker
Aug 30, 2009 | Acer Aspire AX1700-U3793A PC Desktop
Bose Companion 3 and Realtek HD Audio Card - No sound
Hi: I'm sure you checked the volume control of the Bose controller. Check where you plugged it in to the back of your computer. Mine has a veriable outpup and a fixed output. I hope this helps, Jeff
May 31, 2009 | Dell Computers & Internet
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Apr 16, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
SPDIF IN/OUT not working on Gigabyte p35c-ds3r
hiya
you may have to set the input on your deck to digital b4 it will recognise the signal
Rik
Feb 21, 2009 | Gigabyte Computers & Internet
No Sound
ATI is the graphics card developer. Your motherboard has onboard audio that appears to be Realtek. You should not have an ATI sound driver... as they don't exist.
I'm assuming you're using WinXP to make thing simple. If you're using Vista, try to do the equivalent.
Since your graphics card is capable of HDMI, the problem could be that the card expects to output audio through your graphics card rather than the sound card. Check start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings -- go to the Audio tab and make sure it says Realtek for output. If it shows more than one output device, set it to realtek. If it doesn't show realtek, follow the below instructions, and then double check at the end that the Output device is set to Realtek.
1>Please go to HP's site and download their Audio drivers.
2>Go to Device manager -> Sound, Video, and game controllers.
2.1> Does it have an entry saying "Realtek blah blah Audio" there? If not, what entries does it have for audio? Ignore Audio Codecs and Legacy Audio Drivers.
2.2>If there's nothing there, you need to install the drivers you downloaded. If there is something there, please continue to #3.
2.3>After installing the driver, restart computer.
2.4>Once computer is restarted, go start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings. Hit the button labeled Advanced and adjust the speaker setup to whatever you have - surround sound, 5.1, quad, stereo, whatever.
2.5> Go to #5
3> If there is anything that says Realtek/Azalia Audi, right click it and Uninstall.
3.1> Restart computer.
4>Install audio driver you downloaded, and perform #2.4.
5>Find the driver icon (there's probably on in the task tray) or find it under start -> Control Panel -> Sounds and audio. Set your speaker settings there as well. Audio I/O should specify what ports go to what speakers What you set in windows should match the Realtek audio manager's speaker setup.
If problem persists, please report this.
Dec 14, 2008 | Computers & Internet
ASUS P5B-MX MoBo Very low sound output.
inthe realteck sound system there u need to adjust the settings in the software set the settings to 2 channel
Oct 24, 2007 | Gigabyte GA-945GM-S2 Motherboard
Acer Aspire 4520-5582 Notebook Logo
5,607 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
