Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Air conditioner e4 comes up when we turn on the air con , we have power, air flow and then it cuts out
You want me to tell you how we fixed the problem, well seen as your add says free solutions, and then there is a charge, I will tell you how we fixed our Air Contioner probkem, when you forward me your credit card details and for a small fee we will give you the imformation you have asked for...
Posted on Apr 25, 2008
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
E4 Error Message
ok sir! are you sure is the sensor are cleaned? your unit need to general cleaning specially the sensors!
Oct 16, 2007 | Kenwood KW85 Air Conditioner
Need manual for a heller portable air conditioner. Model: GUSTY10CO
I have a Heller Gusty10c0 Portable Air Con. When It hasn't been used for a while. I turn it on and it last about 10 minutes then just stops. Then when ever I turn it on it cuts out after about 30 secs to a minute. Can anybody help me please?
Dec 12, 2010 | Heating & Cooling
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
I have a air con in the bedroom and it kept coming
it can be due to compressor not working or Refrigerant leakage
Mar 04, 2010 | Heating & Cooling
When air con swiched on heat after a few minutes it closes and the figures e4 and 58 come on. product is aqv12v
E4 meaning high discharge temperature or pressure. Not able to find 58 but I know it also is a refrigerant issue dealing with pressure. Have a tech come in nd do the following:
Normally in cases like this your best option is to reclaim the system, pull a deep vacuum on it and then recharge it with fresh refrigerant by weight as per the manufacturer's recommendations.
Jan 15, 2010 | Samsung Heating & Cooling
E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Jul 12, 2009 | GE APH10AA Air Conditioner
Light not coming on after power outage
try resetting the circuit breaker.
Mar 08, 2009 | Hitachi Heating & Cooling
Air Con cuts in and out and so does cooling fan
I have a 2008.5 Mazda 3 GS Sport and when you turn the air flow selector to windows or windows/floor, the air condition will turn on automatically. (Can't turn it off.)
Nov 12, 2008 | 2008 Mazda Mazda3 Hatchback
Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Dec 28, 2007 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
184 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
