Question about Samsung Televison & Video
Samsung le40n73bd lcd tv, digital stuck on one channel, can get into channel manager to search for new channels
SOURCE: Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Posted on Dec 30, 2007
SOURCE: Grundig colour tv lost digital channels
go to menu, digital setup, then auto tune all the channels again. it worked fine for me :D
Posted on Apr 04, 2008
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
kevin000
  • 1847 Answers
SOURCE: Telefunken analogue color TV model
you have to change the port at the back of the TV. shift to another input.
Posted on Sep 14, 2008
SOURCE: How to update digital channels correctly
the information I needed was in the FAQ's area. Thanks
Posted on Jun 06, 2009
Why am I stuck on one channel
There is only one channel in auto search. Just open searching menu and auto search again your new channels.
Jun 01, 2014 | Element ELC-HS321 32 in. LCD TV
Want to run Dish network DVR 2nd TV thru cable to Sharp lc-c5255u Dish uses channel 73. It was not on my TV. I did a channel search and it did not find it. It also erased all channels and I can't...
Go into the setup menu and do a channel search again selecting digital and analog channels. Then change the input type to cable and you should get your channels back.
Aug 31, 2011 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
My samsung lcd television is stuck on one channel on digital input, so I am watching analogue. can you help?
First of what is the exact model of your samsung tv, Also what do you mean its stuck on one channel on digital input? What input are you using? If its standard cable, have you set the tv to catv and done a channel scan?
Thank you,
Lee
Mar 15, 2010 | Televison & Video
Icannot access dmenu on the remote. samsung le26r7
my samsung le32 tv is stuck on BBC 1 Mono. i cannot access the D menu or change on to any DTV channels. I am in an area that broadcasts in digital. the tv works ok if I connect a freeview box
Oct 01, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Jun 05, 2009 | Sansui 19 in. LCD TV
Lost ITV channels and C4
I think you need to get Sky because it will give you 100% coverage of all terrestrial channels. You may need to retune the television otherwise just get sky
Dec 31, 2008 | LG 32LX1D 32 in. LCD Television
My tv is stuck at one channel. Which controller board has to be replaced? The Key controller,LCD controller, or what?
I got the same problem, TV stuck on one channel, what I did was, I remove the cable (fron the back) for a minute and then reconnect, work perfect, well, better than try to return the bloody thing.
Good look with your.
D.
May 01, 2008 | iLO 3200 32 in. LCD Television
TV gets stuck on channel, won't advance past channel 7.1
Try doing the Channel Search again. See if that helps.
If not, sounds like the Digital Board could be defective. Since this TV is brand new suggest calling your local sharp authorized service center to replace that board under warranty.
Mar 16, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Digital Tv stopped working
I have got samsung 40 lcd is working fine but dtv got stuck on one channel. Its not moveing from one channel I have tried everything. Its not workig. please can you email me your suggestion to solve this problem.
Email address: fazalhareef@yahoo.co.uk
Dec 15, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Televison & Video Logo
55 people viewed this question
Henry  Thomas
Henry Thomas
