Question about HP Pavilion a1410n (ER890AA) PC Desktop
No audio output in my computer - HP Pavilion a1410n (ER890AA) PC Desktop
    Problem Solver:
  • 13 Answers
Run windows update, then follow the directions below.
First verify you see a small sound icon in the Systray . If this icon is missing follow the below section
1. Open the Control panel
2. Open the "Sounds and Audio Devices" icon.
3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
4. If you were able to check this box, click ok and close out of this window and the Control Panel.
5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application
Posted on Aug 30, 2010
My pc says no audio output device installed,but in device manager it says its working properly and the drivers are up to date
Well it is possible that the audio driver installed is not the one compatible with you computer board. Try downloading the specific driver needed for your computer's official website. This should solve your problem.
Sep 06, 2011 | Computers & Internet
Audio output device
Hi.
The audio output device in your computer is the audio adapter board (or circuit). This is the device that produces sounds and send them to the speakers.
If you get a message telling you that there is no Audio Output Device detected, or that the Audio Device is not working, that usually means that there is a problem with the audio driver.
In that case the problem is often fixed downloading and reinstalling the drivers for your audio device. If there is a problem with the audio output device, go to the computer manufacturer website (e.g. Dell, HP, Sony etc.) and download the audio drivers for your specific model. When download is complete install the drivers and restart the computer.
Regards.
Ginko
Jul 20, 2011 | Microsoft Windows Vista Home Premium with...
Don't know how to connect to tv
If the TV has audio output available, there will be RCA jacks somewhere for that. The standard colors are red for the right channel and white for the left, and they'll be clearly marked as audio outputs. Not all sets have audio outputs, though, while they usually have audio and video inputs. So if you find RCA jacks on the set be sure to see how they are marked.
If the TV has output jacks, all you need is a cable with the appropriate plugs at each end. The TV needs RCA plugs, while the input connector to the speakers varies by manufacturer. Typically the speakers will use a 1/8-inch stereo jack if they were made to be used with a computer, and RCA jacks if they were meant to be used in a home-theater setting. In TV sets with audio outputs, the output may be fixed and independent of the TV volume, which means you can turn the TV volume down and use just the external speakers. Or the audio output may vary with the TV volume, meaning you'll always need to have the TV volume on as well. Some people find this annoying.
If the TV doesn't have an audio output available, you can't hook the speakers to the TV. What most people do in that case is use the TV as a video display in conjunction with an AV receiver. The audio and video sources connect to the receiver, which in turn drives the speakers and provides a video output to the TV.
Feb 27, 2011 | Durabrand 5.1 Surround Sound Computer...
I would like to hook up my amp to my pc or laptop what extensions do i use and what setting do i put it on to receive sound? It's a JVC RX-884V
If you computer has only analog audio outputs, you could use one of the audio components input , turntable, cassette or CD player input, for this you'll need a cable called " Y ", it's called this way because its shape, in one end you have two white and red RCA plugs which are connected to amplifier, in the other end you have a 3.5mm stereo plug that connects to your computer audio output, preferable the line audio output. If you have digital audio outputs from your computer, you can use the coaxial or optical inputs, the first requires a digital coaxial cable RCA plug both ends and the second an optical fiber Toslink cable.
Feb 23, 2011 | JVC Audio Players & Recorders
I have connected my PC to Panasonic TH-L24C20D, I want audio output via TV speakers. what to do?
If your computer has an HDMI output, the audio is already connected to the TV in digital format via its' HDMI input. However, if you are using the VGA from the computer, you will need a separate audio system to output the audio from your computer. The VGA is an analog video only. Your TV does not have an audio input so therefore you need a speaker system from the computer.
Dec 20, 2010 | Panasonic Televison & Video
My Dell A225 Speakers do not play audio- just the computer sounds.
Test this setup with your walkman/ipod.
The most likely problem is in your computer's mixer selection.
Put a CD into your computer drive and play this CD.
If the CD audio output is low then dial up the mixer CD output.
If you do not has audio via CD at all then the CD drive to sound card audio cable is disconnected.
Jul 08, 2010 | Dell Audio Players & Recorders
Its appeare in my computer no audio output device is installed
why realtek ac97 audio not being installed in a windows vista?
May 30, 2009 | TerraTec Electronic AudioSystem EWS88MT...
Problems with audio after installing radeon hd 2400
This happens because the video card has hdmi output. Since hdmi output can carry audio signals also, the audio driver gets disabled. Uninstall audio driver and video driver both, install the video driver, and then install audio driver. after installing the audio driver, in playback and recording devices choose choose the audio output device you purchased along with the computer. This should fix the issue.
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 12, 2009 | Diamond Multimedia Stealth RADEON 9250,...
LOGITECH X530
Locate the Audio output on your TV and connect it to ur X530 Audio input. Locate ur Audio output (exa. AUX-OUT, MONITOR OUT, ETC..) on ur Home audio then connect it to ur X530 audio input. Goodluck
Aug 11, 2007 | Logitech X-530 Computer Speakers
HP Pavilion a1410n (ER890AA) PC Desktop Logo
213 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
