Question about DeLonghi Pinguino PAC-210 Air Conditioner
Pinguino PAC160 and it does not seem to be cooling to max.
Good morning
We have a Pinguino PAC160 and it does not seem to be cooling to max.
There is some cool air coming out. A FL was flashing this morning so I emptied the water reservoir, it was less than half full, and I removed the filter. It seems to be working a bit better but I remember it putting out way more cool air than it is now. I have the temp at 61.
Is there something I am missing?
Angela
SOURCE: is this thing working?
I had the same problem...I was going to get rid of the unit...I notice that tha red light on the little screen on the top was on...then I closed the tray (all this time I though it was closed) all the way and the red light went off and the unit started cooling! I hope this may help you.
Posted on Jul 31, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: DeLonghi Pinguino PACL90 MODEL
For a short time you can run without filters. I suspect it is low on charge or the metering devise is not working. Check this link out for an owners manual. It may help you.
http://www.manualnguide.com/download/manual-guide/delonghi-pinguino-pac210-portable-air-conditioner-owners-manual.html
Posted on Aug 19, 2008
SOURCE: Empty wateron DeLonghi Pinguino Pac L 90
That probably is Ft, meaning full tank. Look on the bottom of the back side, and there should be a small "hatch" that will open. The two small hoses in there are drain hoses that can be unplugged to drain the tank. They're right at the bottom, so if you have a way to raise the unit up a little that would let you drain the water into a container. Might be a good time to clean the filter too.
Posted on Sep 19, 2008
SOURCE: k 900, pinguino
I had the same problem with my Delonghi K900.  I have an extended warrantee for both my Delonghi air conditioners.  It was taken into the shop and discovered that the hose that allows the water to drip into the collecting tank was clogged with dirt and dust. I find it is a good idea to have them cleaned and checked once a year, especially if used often. For under a hundred dollars, I have a warrantee that will last until the year 2010.  Sears offers warrantees for any home appliance, even if it wasn't purchased there. Taking the air conditioner apart yourself can cancel any warrantee on them machine. Hope this helps. Trisha
Posted on Nov 11, 2008
  • 66 Answers
SOURCE: DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Posted on Feb 19, 2010
I just bought a used DeLonghi Pinguino PAC 02. It seems to cool ok but the exhaust hose gets very warm. Is that normal?
Yes, that is normal. It's exhausting the heat from the compressor out the window.
Thanks for choosing FixYa.
Sep 09, 2011 | DeLonghi Pinguino PAC-02 Air Conditioner
Not Cold Does not cool warm air comes out of it
The compressor is locked up and making heat..
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 06, 2010 | DeLonghi Pinguino PACL90 Portable Air...
My delonghi pinguino pacl17 does not cool enough, doyou have a telephone number i canreach you. It only cools to 64 and its not cooling enough,
heatman101
Aug 27, 2010 | DeLonghi Pinguino PAC-GSRU Air Conditioner
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi PAC F10 air conditioner doesn't seem to be cooling
It could well be low on refrigerant, as well as a multitude of other possibilities. I'd have it serviced by a pro.
May 07, 2009 | DeLonghi Pinguino PAC-F10 Air Conditioner
No cool air and oil in one of the drain lines
I would say that you have a refrigerant leak. The oil was pulled out of the compressor and leaked out with the refrigerant.
Jan 17, 2009 | DeLonghi Pinguino PACL90 Portable Air...
My AC is not cooling the air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Aug 04, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Pinguino pac-166 not cooling enough
CHECK AND CLEAN THE DUST FIELTER AND ALSO CHECK THE BLOWER THEN TRY IT
Jul 06, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi piguino k900
does anyone no where to find a user manual for this air conditioner?
Jun 08, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi Pinguino PAC-210 Air Conditioner Logo
49 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
