Question about Car Audio & Video
I have a jvc KS-R135 car stereo but no wiring diagram. I need to know what each wire is for and if the case is grounded in addition to whichever wire is a ground wire. I need to know which are the speaker wires and which ones to use for a 2 speaker system. also how would I connect up a power antenna? The one wire that is labeled is a blue/white wire for a power antenna. could you also send me a pdf of the wiring and of the manual?
  • 164 Answers
SOURCE: JVC CarAudioModel KS-RT404 lost rear panel containing connections
http://files.ddrservice.info/Audio/jvc/ks-rt404.pdf
This link will take you to the manual. On page 7 you will find the connection Info. you need.
Posted on Sep 18, 2009
Testimonial: "Just now, "kristymahar" you are an angel sent to solve my car audio problem. May your tribe multiply so you will be able to help poor souls like me. "
KaeZoo
  • 156 Answers
SOURCE: wiring diagram
Red: voltage source controlled by the ignition key Yellow: constant voltage source Black: ground Blue: power antenna activation wire (if equipped) Blue/white: amplifier activation wire (if equipped)
Posted on Jun 06, 2007
  • 243 Answers
SOURCE: MOTHERBOARD WIRING
Instructions should be in the manual found here
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=302
They sound like they are for your from usb posts on case...but thats just a gues :)
Hope that sorts it for you?
Posted on Dec 30, 2007
  • 290 Answers
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
Posted on Mar 26, 2009
motor1258
  • 6674 Answers
SOURCE: stereo wire color > front doors speakers
Try this link.
http://www.the12volt.com/installbay/stereodetail/1412.html
Posted on Aug 16, 2009
Testimonial: "exactly what i needed. THANKS "
I'm trying to install a JVC cassette receiver
Try checking here for wire color codes to coincide with deck.
http://www.the12volt.com/installbay/stereodetail/159.html
May 08, 2011 | JVC KS-RT320
Need wiring diagrahm for jvc ks-r135
Hello here is a diagram to help you out.
Mar 24, 2011 | JVC Car Audio & Video
Need wire diagram for 2001 toyota tacoma for installing JVC kw-nt3hdt stereo or any advice
Hi, here are your factory wire colors/functions. Aftermarket stereos have a common set of colors, which should be in your installation diagram. The process is simplified if you purchase a wiring adapter for your vehicle. These are available for under $10 at most WALMARTs and auto parts stores or about any place that sells car stereos. In either case, I recommend you solder the connections or at least use crimp terminals. If you have any more questions, please let me know--I've done a lot of stereo installations.
2001 Toyota Tacoma Car Stereo Installation Guide
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jan 07, 2011 | 2001 Toyota Tacoma
Wiring diagram for jvc model no ks-fx460r
http://books.jvc.com/booklist.asp?Model=+ks-fx460r this should take you to the down loadable manual for that head unit.
Jan 12, 2010 | Car Audio & Video
Sep 18, 2009 | Car Audio & Video
I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 03, 2009 | JVC KW-XC777 CD / Cassette Player
Wiring Harness for JVC KS-R127
I can uually find those on ebay for a few bucks. You will need to count the number of pins then go shipping.... Also look for a seller called cali car stereo if they dont have it listed they probhably have it at thier store..
Sep 08, 2007 | JVC KS-R127
Car Audio & Video Logo
272 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
