Question about Haier Preference Plus HWR18VCA Air Conditioner
How do I get the coolest air from from my ac?
  • Haier Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
I have a haier air conditioner 5000 n it not blowing cold air its not cooling my house
check thermostat turn off system wait 3 to 5 minutes turn on to cool and turn thermostat to coolest setting if no compressor test thermostat and compressor check filter if dirty and coil iced turn off and lit defrost and change filter if coil warm and unit running compressor internal damage or low freon
Jul 28, 2016 | Haier Heating & Cooling
AC compressor clicks on and off while running?
the compressor will cycle on/off when the cabin temperature is reached
the larger pipe will be cold to touch as it is the suction line for the compressor
if you have a problem with the ac ,it will not work the compressor at all and the lines will not get cold
When in doubt take it to an accredited ac specialist shop and have the system check out.
Aug 11, 2015 | 2000 Cadillac Escalade
I have a Kia Sephia. When I turn on the ventilation system / fan on the coolest setting it still runs warm. (The car does not have AC.) On a hot summer day it is unbearable. What is wrong with the system?...
unfortunately your only going to get whatever cool air is outside, the vent system on a Kia and most cars with no AC is just to circulate "new" air into the vehicle, so if its hot outside, thats the air your going to get inside .
Jul 24, 2011 | 1999 Kia Sephia
My 2001 sienna air conditioner is blowing some cold air but could be colder. Can I just replace freon?
A lot of your local parts stores sale a hand held device that you pull the trigger on with it hooked to you ac line and it will tell you if it is low or ok or over charged. It comes with a can of R134 and I think it was around $40 but it is well worth it so you don't over fill andlock up your AC pump
Jun 30, 2011 | 2001 Toyota Sienna
How can you tell your a/c is ready to replace it`s coolant gas? My 2007 elantra particularly on a hot day doesn`t send cold cold air at the coldest level indicator It is cool but would that indicate the...
To tell if the ac coolant requires replacement the car will not cool when the sun is out and at all time you might have to put the car ac in coolest to enable a little bit of cold air.
Also the back seat will not be cool except the car is running on the highway.
Gas might be leaking somewhere.
Good luck
May 27, 2010 | 2007 Hyundai Elantra Limited Sedan
Cant find my low port to charge my air conditioner - dont have my manual
On my 1998 Sienna (when facing the engine), the low port is located on the left side near the back, between fender and the engine. Is is marked with a back cap that has an 'L' on it.
Apr 06, 2010 | 2000 Toyota Sienna
My climate control starts blowing hot air while a/c is on
Make sure you have fully charged AC sytem first, if so Im sorry to tell you this but this is a difficult deal.you may not be able to correct this without taking it to a repair shop with gm scan tool. Reason being the actuators for the hvac that most likely are malfunctioning from either them or another component being bad , require recalibration.The other reason would be the body control module related.It would have to be scanned for U codes which can effect the hvac control.Sorry but thats what I know.
Sep 06, 2009 | 2003 GMC Sierra 2500HD
My 2003 xtype battery went dead and I had to replace it and now my ac doesn't work, blows only hot air and it was working fine before.
your computer needs to be reset.. go out turn the car on. turn the air all the way up as hot as the temp will go, let it run there long enough fro the heater to get hot... then turn it all the way down to the coolest temp and hit ac it will cool down.
Aug 25, 2009 | 2002 Jaguar X-Type
Haier Preference Plus HWR18VCA Air Conditioner Logo
60 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
