Question about Maytag PAV2300 Top Load Washer
With a cracked tub o a washe tuber, is replacing the tub the only solution, or is there some type of sealant or adhesive that could be used?
    President:
  • 1,554 Answers
You may use a two-part epoxy adhesive/sealant but the cause of the crack must be addressed first. The tub will eventually be damaged completely if there's an issue with the inner basket banging the sides of the the tub. Address any balance issues then take the tub out to apply the sealant properly.
Posted on Jul 09, 2010
  • 1 more comment
  • busy74 Jul 09, 2010
    how do i address the balance issue?
  • Jahn27
    Jahn27 Jul 09, 2010
    Check to make sure that the suspension springs are securely attached to the suspension housing. Remove the front panel and the rear access panel for complete access to the suspension springs.
  • Jahn27
    Jahn27 Jul 09, 2010
I am having trouble with the sealant cracking on my American standard saver acrylic tub/ surround.
If you have movement on the tub it will not seal . you will have to solve the movement first . General sealant which does not mould will normally work .
Oct 08, 2017 | Plumbing
The rubber seal on the front opening has come loose
How to Replace Washing Machine Door Seal
Whether a high temperature adhesive sealant is used for your particular washer is something that may have been obvious when your seal came loose.
How to Change the Rubber Seal on an LG Washing Machine
Sep 02, 2017 | Washing Machines
How to replace Drain pan?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on the upper side of your fresh food section wall.
Generally there are only two types of drain pans:
1.) One is mounted on the top of the compressor and fixed with a high temperature adhesive which over time the adhesive dries out and cracks and the drain pan falls off and you have a flood. Just bad design.
While in the field I would use duct tape to remount it.
2.) The other, although the part is available, can not be removed due to interference with the compressor tubing and other components. At the factory the drain pan was put in before the compressor and other components. Just Bad design.
When you have a crack or leak - I used duct tap to line the drain pan. Then I used a good high temperature silicone adhesive as a sealant over the duct tape.
This may not sound like a very professional repair for a certified field technician, but this is what we all did due to poor design.
May 13, 2015 | Refrigerators
WHAT IS THE SITUATION FOR A LEAK ON OILPAN
new late model vehicles use an adhesive sealant when they fit the pan to the block. Over time this adhesive can break down and leak but this takes years on over 100.000 miles and the replacement is a gasket that you use good quality sealant with..
Dec 10, 2014 | Cars & Trucks
Can i use an adhesive as a sealant?
i recommend going to the store and getting a proper sealant. adhesives are generally used just to fill a gap, while sealants are more used for actually fully sealing the gap off
Jan 15, 2013 | Adhesives, Coatings & Sealants
My waterrower has a leaking seam in the plastic tank. I know its not that expensive to get it fixed, but its a big hassle...80 mile round trip in heavy traffic. Is it ok to use plastic sealant like you use...
I sealed my tank seal permanently and also fixed cracks on the bottom with Loctite PL Marine Fast Cure Adhesive Sealant. On the inside when the tank was apart I glued a heavy plastic patch directly over the cracks in the bottom. I made the patch from a flat section of plastic cut from an old refrigerator crisper drawer. After installation with the tank laying flat and level glue the upper side of the tank to the adjacent wood for stability. Wait a few days before filling. Photos are attached. Loctite 10 fl oz PL Marine Fast Cure Adhesive Sealant 2016891 The Home...
Dec 28, 2010 | Water Rower WaterRower A1 Rower
Washing Machine Emptying
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
May 27, 2009 | Washing Machines
Washing machine problem...
A good marine type silicone sealant (like what you might use on boats) might buy you some time. However, with the vibration of the machine and the torque applied to the tub when the transmission and drive motor engage to spin will only make the crack worse over time. Sorry, but you might want to think about replacing the tub.
Aug 11, 2007 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Maytag PAV2300 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
