Question about Honeywell CT3200 5-2 Day Electronic Programmable Thermostat Heater
Honeywell thermostat stuck on bae lo how can it be reset?
3 Suggested Answers
  • 252 Answers
SOURCE: Honeywell thermostat flashes Lo Ba??
replace battery. the front should pull off. if that dosent fix you'll need a new thermostat
Posted on Jun 06, 2009
  • 252 Answers
SOURCE: honeywell thermostat for a/c heat pump shows the
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Default.htm
Posted on Mar 11, 2009
Hunter 44860 touchscreen thermostat- My thermostat displays "LO". My wife said she played with it and can't fix it. He heat won't shut off! I thought it was the batteries so I replaced them. I noticed...
I suggest to everyone NEVER to buy a cheap thermostat from any box store regardless of brand. Always go with Honeywell or White Rodgers high end stats and DO NOT lose their booklets.
Feb 19, 2015 | Heating & Cooling
Honey wire
Look for reset button push in and try to Program if this doesn't work time to replace T-Stat.
Jul 05, 2013 | Honeywell Programmable Thermostat Heater
Our Honeywell programmable thermostat T8132A 1049 1 controls a Gasglo gas central heater. An old battery leaked onto one battery contact; even with new batteries the BATT LO message came up. After...
The T8132A thermstat requires 2 AA alkaline batteries for operation as the T8131 uses the 24VAC souce transformer with battery back up. If new batteries did not fix the problem follow product user manual to reset and program the thermostat. This should clear any errors or problems. If the problem persists then replace the thermostat. If you do not feel confident you can accomplish the task then you should call a licensed HVAC technician to troubleshoot the issue as the wrong settings could potentially cause permanent damage to your system.
Link:
http://s3.pexsupply.com/manuals/1287594709924/40775_PROD_FILE.pdf
May 09, 2011 | Honeywell Programmable Thermostat Heater
We have a Honeywell Digital thermosat. We just put brand new batteries in it and it is still showing lo battery.
on most of honeywell units if you pull the face of the thermostat off there is a reset button you can puch and reset try this.... if it does not have a reset remove the red power wire on the "r" terminal and if you have a wire hooked to the "c" terminal remove it at same time ///take batteries out prior to doing this and it will reset the program in thermostat... if the display comes back again with the lo battery the thermostat internally has a issue...good luck
Jan 09, 2011 | Honeywell Programmable Thermostat Heater
Bae lo This is the message my electric Honeywell programable thermostat is flashing. It's still working. What's that mean? Thanks.
Try with this site:
Honeywell thermostat website: http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating
Dec 12, 2010 | Heating & Cooling
I replaced the batteries in my Honeywell CT3300 and the "Bat Lo" message won't go away even with fresh batteries. Is there a reset button or something?
Per manual do this: System set to Off Remove batterie Replace IN REVERSE POLARITY POSITION or 5-10 seconds Put back in with CORRECT POLARITY Reprogram per sticker on back of thermostat. Done. Just did this myself and it's simple and effective! PaulHaven
Oct 14, 2009 | Honeywell CT3200 5-2 Day Electronic...
My thermostat keeps saying BAE Lo
I just looked up this issue tonight. The batteries in my thermostat needed to be replaced, so I replaced them with two new double AA batteries and now all is well.
Sep 21, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
906 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
