Question about Haier hwr10xc6 Air Conditioner
Water drip where is water drip outlet please ???
  • Haier Master
  • 43,501 Answers
The water just drips outside from the back of the pan...make sure it is tipped back towards the outside...
heatman101
Posted on Jul 12, 2010
We have a Axiom 12 cup automatic. We have been having issues with the hot water spiket dripping. Any ideas why and how to fix? Thanks
u mean dripping on the water outlet on top of ur server ? ur dripping solenoid plunger might be already open a bit or ur incoming solenoid valve not closng properly
Jul 11, 2014 | Bunn Hot Water Dispensing Faucet
Celiera 51GW 18000BTU mini split a/c heat, water collects on top rear coil and drips into fan housing and comes out bottom
While cooling, water is supposed to drip off the evaporator coil and flow out the unit. That's a feature of air conditioning. You get a little bit of control of where the water drips to by installing tubing to conduct the water wherever you like, unless the outlet port is plugged up. Poke a toothpick up it and see if that unclogs it.
May 13, 2014 | Haier HEATER CPN10XH9 Air Conditioner
Gss201epc refrigerator water drips from water outlet in door even when water is not called for
Water valve in the door is bad. Valve is not shutting all the way off when not in use.
Apr 01, 2014 | GE GSS25LGM Side by Side Refrigerator
Amana furnace model amv9 has water dripping from the exhaust outlet. the exhaust doesnt seem to be clogged and the overflow for water to run into doesnt seem to be clogged. water is makign its way int
You did not say if you have a dehumidifier or air conditioner installed on this unit. If those are not installed on it then the only place moisture could be coming from is down the exhaust connection for the flue. If one or both of those items are installed then the issue is the drain trays might have debris built up that you cannot see.
Mar 23, 2014 | Heating & Cooling
Water dripping from blowpipe
It is normal for water to drip out sometimes from the pressure relief valve outlet pipe. If it drips continuously then open and shut the pressure relief valve several times so the pressure relief valve shuts off properly.
If this does not fix the dripping problem then the pressure relief valve is faulty and needs to be replaced.
Apr 02, 2013 | Water Heaters
Hello I have just purchased a secondhand hotpoint MAC 130 airconditioner and it is running well however water is dripping from a black outlet at its base. Should there be a hose which attaches/srews onto...
The bigger hole is a drain plug to quickly empty the unit, it should have a runner bung plug and shouldn't leak, the small tube is all you need to get excess water outside
Feb 03, 2011 | Heating & Cooling
My Keurig is just dripping into my cup. What should I do? What is the best way to clean it?
I blew out the tip and the water intake with my nail gun air compressor. Tried the tip first without any results. After I tried the water intake, hot water started to drip from the tip. Worked fine afterwards. Like other people have stated, water will spray, so make sure you cover the inlet and outlet areas with a towel. Their is a second outlet that is a piece of rubber that drains into the back of the water storage area. It points down and is ment to drain back into the water holding tank. Hot water could spray onto you hand after using the compressed air so be careful.
Aug 17, 2010 | Keurig B70 Coffee Maker
Danby continuous water flow will not work on a dehumidifier it still fills the bucket
Please try the following:
1) Remove the bucket.
2) You will notice a round outlet/spout where the water drips from into the bucket.
3) Remove the plug from the backside of the unit (you will now see a hole to the bucket area).
4) Feed a hose through the hole from the back and attach the end of the hose to the round outlet/spout.
5) Place the other end of the hose on a floor drain outlet.
6) Put the bucket back into the unit.
When the unit is turned on, the water will now flow through the hose instead (into the floor drain). When you want to use the bucket again to capture the water, you will need to remove the hose.
I hope that helps.
Apr 25, 2009 | Danby DDR601 Dehumidifier
Water Leak UNDER the Vehicle.
It is definately your AC water outlet. The hose must have shifted sort of.
Rate this please
Apr 04, 2009 | 2001 Toyota RAV4
GE TPX24 BRBJ side-by-side drips water from door dispenser
water valve is behind ref.on either the right side or left but you will see your water line going to ref.water valve.Most likely replace.
Mar 06, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
Haier hwr10xc6 Air Conditioner Logo
269 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
