Question about Sylvania SRC22134 13 in. TV/VCR Combo
My tv keeps shutting off and won't play tapes how do i get it to not do this
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
I am trying to fix mine, vcr tape won't stop playing when it reaches the end of the tape, keeps breaking tapes. I was told it was the motion sensor, am trying bto locate the part!
Find your local authorized Emerson Warranty Center
In U.S.A.
For all product purchased in the U.S., please contact:
Emerson Radio Corporation
9 Entin Road
P.O. Box 430
Parsippany, New Jersey 07054-0430
General questions and comments
internet@emersonradio.com
About my order
Toll-free: 1-800-909-1240 (between 9:00 - 4:00 CST)
Print this out
Take unit in for fix or replacement.
May 23, 2011 | Emerson EWH100F
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
Tascam 38
Usually the tension of the take-up reel keeps the shut-off arm taught and everything works. If the shut off arm falls down, the recorder stops. Is that what's happening?
Inadaquate (or NO) take-up tension can cause this; so can WARPED take up reels. Another possibility: if you play a lot of old tapes, the groove in the shut-off arm collects dirt and oxide, so the tape - as it goes through it - jams, and the take-up reel can not overcome the tension. The arm "falls down" and shuts off the machine. Also SOME tapes (which were "cut down" from 2"
tapes) are poorly ****, and will jam some machines.
This is what I do for a living, so if these suggestions don't work, give me more information, and I'll solve your problem.
Jan 01, 2008 | Audio Players & Recorders
Power problem
Has this just started happening? What did you do just before this happened? You need to supply much more information, we are not mind readers! What's the make and model, this ain't a generic problem!
Oct 06, 2007 | Quasar VV1309 13 in. Combo
TV keeps shutting off after 10 seconds
It's possible from what you described that your center LED or prisim was broken when the tape was extracted. Like many others these units depend on a series of startup checks and one being the tape path. On the play table of the VCR is a center prisim/LED and two light sensitive diodes on either side of the tape loading assembly. If these diodes do not detect the infared beam the unit will go into shutdown. I'd check there and let me know. Bill
Jun 03, 2007 | Sylvania 6319CC 19 in. TV/VCR Combo
Sylvania SRC22134 13 in. TV/VCR Combo Logo
35 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
