Question about Whirlpool ACQ158XP Wall/Window Air Conditioner
When using Power Saver, should speed be Low or Auto
What is best speed option when using power saver ?
  • 455 Answers
Hello Gkittels The slowest/low speed will save the most energy and cost less.But see if that setting will still get the job done you might need more on hot days.
Posted on Jul 09, 2010
How to get the best battery life
Download a battery saver app from the play Store I use DU Battery Saver I also use DU Speed Booster to keep my ram low
Mar 06, 2014 | Boost Mobile Lg Venice No-contract Mobile...
Laptop gos into screen saver mode then screen turns black and you have to shutoff with the power button and turn it back on to use it again tried turn off screen saver with no luck after about 3 min. the...
Unless you have already done so, check the power saver options in the control panel. You may have to tweek the timings to make sure power save options are not cutting in too early.
I don't know which windows operating system you are using but generally you will find the details in the Control Panel.
May 13, 2011 | Computers & Internet
When I turn on my computer, it says it is "locked". It also asks if I want to "switch users". I am the only user. Secondly, I would like to know how to keep my screen saver on at all...
When you set the screen saver there will be an option for the computer to be locked after like 15 minutes idleness. You need to disable it to keep your screen saver on at all times. It is either in your graphic properties settings about screen savers or the power options you can open with a button on the dialog box of screen saver settings or you can open the power options from control panel. If you tell me which operating system you are using I will show you the detailed steps.
Apr 23, 2011 | Computers & Internet
Remove screensaver from TV
Hello
You are refering about energy saving function I thinks. To energise this function, surf through its menu and come towards energy saver.
This power saving feature reduces the backlight
brightness level. The options are:
OFF-the feature is off and the power consumption
is normal.
LOW-power saving level is low and the backlight
brightness level is lower than normal.
HIGH-power saving level is high and the backlight
brightness is set to the lowest level.
1 Use the CURSOR Up or Down keys to highlight
Energy Saver. Press ENTER.
2 Use the CURSOR Up or Down keys to select Off, Low,
or High.
NOTE:The Energy Saver settings level varies with
the Picture / Sound mode.
OK.
Feb 20, 2011 | Sanyo 42 in. LCD TV
LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Dec 18, 2009 | LG Flatron L1750S 17" LCD Monitor
When I am not using my laptop screen, it turns pink. After I start using it again, its allright. Is my screen going bad?
check ur screen saver, may be the screen saver has been set for the option to chose the pink color.
if it works when u use it the screen is OK...
check ur Power option in Screen saver....
Dec 17, 2009 | Computers & Internet
The screen power saver kicks in after only 60secs. I know I'm dense but I cannot find how to alter this.
Click on START/Control Panel/Power Options Once in Power Options you can choose how long before the monitor shuts off or not at all. You will have 3 options, High Performance, Power Saver, or Balanced. You should also see options to the left where you can create your own Power scheme.
If running XP, your options may vary but still click start/control panel/Power for your options.
Hope this answers your question. Best of luck.
Greg
Nov 05, 2009 | Acer Aspire One PC Notebook
Viewsonic monitor shuts down
try check your screen saver setting, it might be the time of screen saver to appear when PC not used, screen saver might be in blank.cheers.
Jan 21, 2009 | ViewSonic VA1912w 19" LCD Monitor
The brightness level
You need to use the Toshiba "Power Saver" console. Go to Control Panel -> TOSHIBA power saver. Click the Icon and use the console to adjust the brightness for the various power schemes. If you don't see the TOSHIBA power saver icon, go to Go to Control Panel ->Power Options and open that console. Select "TOSHIBA Power Saver" option in the "Power schemes" dialog box. If you don't have that option in the dialog box, you need to go to the Toshiba site and download the Power Saver installation file and reinstall it.
Jan 11, 2009 | Toshiba Satellite A45-S151 Notebook
Sattelite M30,model no. PSM-30L-Power saver download
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/askIris.jsp
Jan 02, 2009 | Computers & Internet
Whirlpool ACQ158XP Wall/Window Air Conditioner Logo
135 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
