Question about Canon imageCLASS MF3240 All-In-One Laser Printer
Paper jam I have MF3240 image class and have paper jam? What could be wrong?
    Genius:
  • 1,040 Answers
Visit to the given link for solution....
http://support-sg.canon-asia.com/contents/SG/EN/8000572201.html
Hope this has helped you... Thanks...
Posted on Jul 09, 2010
I have an imageclass mf3240, it intermittently prints out wrinkled pages. I would like to see if it is repairable, i did only pay $200 3 years ago so if it is cheaper/easier to just buy a new one I will. I...
Hello Lea! Welcome to FixYa!
If your printer prints wrinkled pages then first of all it may be because of paper jam or paper tray, their may be a small sheet of paper remain inside causing problem or the paper tray is not properly inserted, So check there must not be any piece of paper or if paper tray is not properly inserted, Insert it correctly.
If problem is still there then this problem is usually caused by the Fuser assembly or Tension Roller of the printer. You need to change the tension roller of the printer and if need then change the Fuser Assembly. My advise is as it is technical hardware problem so you must consult with Canon Authorized Center and they will replace the roller of the printer and if there will be need they will change the Fuser Assembly of your Canon image Class MF3240 printer
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Mar 03, 2012 | Canon imageCLASS MF3240 All-In-One Laser...
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
We have a Canon Image Class MF3240 Copier/Fax/printer/scanner. We are receiving error A4-load proper paper. We are loading with 8 1/2 by 11 paper. What is this error telling me?
The problem is on the computer, not on the printer.
"A4" is a paper size, just like "Letter" and "Legal".
You probably have your software application, such as Excel, Word, etc., set to paper size = A4.
Do this in your program on the computer:
[File]
[Page Setup]
[Size] "8 1/2 x 11"
... and print your document again.
Mar 19, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Dec 12, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Cannon imageclass mf3240 laser printer paper jam
Hello there,
Hope I could still share with you this fix because this is where you need to look at when you think you have done everything to remove the paper jam.
You can also click on this link for this trick.
http://www.fixya.com/support/r3827902-canon_imageclass_mf3240_paper_jam_fix
Sep 08, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Paper Jam but no papaer found Canon Image Class D860
Have you checked that the paper path is clean and free of paper fragments which sometimes get jammed in the sensors? Try blowing them with a compressed air bottle.
Aug 24, 2009 | Canon imageCLASS D860 All-In-One Laser...
Paper jams on Canon MF3240
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jun 17, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Canon MF3240 Paper Jam - No Real Jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Dec 18, 2008 | Canon imageCLASS MF3240 All-In-One Laser...
Canon imageCLASS MF3240 All-In-One Laser Printer Logo
152 people viewed this question
old marine
old marine
