Question about Samsung SyncMaster 740N 17" LCD Monitor
Blow capacitor 820uF 25v? where can i buy them? or how to replace them with other capacitor?
    President:
  • 1,138 Answers
You can buy that to an electronics store near your area. Replace that with same value or if you have higher than 25 volts use it provided that it is same as 820 microfarad.
Posted on Jul 09, 2010
    Problem Solver:
  • 6 Answers
Its so hard to find 820uf/25v.
you can replace it not lower than the original value.
you can try 1000uf/25v
my monitor is blinking for 15min.
when i open it i found a leaky capacitors.
so i replace it.i replace it of 1000uf / 25v and it work.as good as brand new.
Posted on Aug 10, 2011
    Problem Solver:
  • 5 Answers
Rubbish! 820uF are still readily available.
http://lcdalternatives.com/
Posted on Aug 28, 2012
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: blow capacitor 820uF 25v? to replace 1000uF 25V
It is probably OK, possibly a filtering capacitor, besides no one makes a 820uF any more.
Posted on Dec 11, 2010
Testimonial: "thnks"
Capacitor 820uF 25v to replace 330uF 25V ken it work?
No! it will get you into trouble, stick with the value called for but you can up the voltage rating if desired.
May 24, 2011 | Computers & Internet
I needed to replace 2 of my 820mf 25volt capacitors in my Samsung LCD TV. Problem is that I cant find these capacitors anywhere. I did found 820uf instead of 820mf. Are they the same capacitors and would I...
uf is for micro farad.
we have the same problem.
my 820uf/25v in my monitor need to replace but i didn't know where to buy this capacitor, so i try to replace it 1000uf/25v
and the result is OK. my monitor is working again. as good as brand new.
you can replace 820uf/25v by 1000uf/25v because they have a 20%tolerance...
Apr 07, 2011 | Televison & Video
Blow capacitor 820uF 25v? to replace 1000uF 25V other capacitor?
Dec 11, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Hi I need to replace 3 x blown capacitors for my LCD monitor. They are 820uf 25v. Do they have to be an exact match ie ceremic/tolorences?
They can be 1000uf 25v (20% higher value is OK), higher voltage is also OK but it may not fit the board. The temperature rating must be 105c and Low ESR type which is very important for switching power supply. You should replace them in a set.
You can get the PANASONIC FM or FC series from DIGIKEY, or from Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 03, 2010 | Samsung SyncMaster 940N Flat panel Monitor
I have three blown capacitors. they say 820uf 25v. they all solder to the same part on the board. is it necessary to have three of the caps at 820uf 25v. or can they be added up like 820+820+820=2460uf 25v
You need to have the 3 capacitors. There is not a 2460uf capacitor, If one of the 3 fail then the other two will still work, if you have just one capacitor and it fails then you have a dead power supply with the first failure.
Buddy
Corporate Computer
www.ccl-la.com
Jan 18, 2010 | Samsung SyncMaster 940N Flat panel Monitor
Takes 5 to 10 minutes for the video to appear
Sounds like it could be a weak capacitor. Caps that are bad or weak will work after they warm up.
Dec 09, 2009 | Samsung 225BW LCD Monitor
Flicker then display goes black
your monitor got trouble at:
1) monitor inverter board components fail like capacitor or MOSFET diver, it can repair or change this parts to fix.
2) there is disconnection between the inverter and CCFL lamps
need to check by technician, it could be fixed,
3) check the DCpower supply board capacitors swelling which need to reaplace, and fix it.
all steps need to do and fix it well.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 24, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
1,486 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
