Question about Frigidaire ATF6000ES Front Load Washer
How do I change the lightbulb in the Affinity frontloading washer?
4 Suggested Answers
  • 1525 Answers
SOURCE: Code E36 and Code E68
hello e36 means control board problem E68 means current leakage to ground on heater or fuse opened
shaun
Posted on Jan 14, 2009
SOURCE: No panel lights!
Solution - MEASURE voltage in outlet with digital meter and if it is not ~115 V or very close do nothing - wait till it gets to norm.
Longer explanation:
I had similar problem today. Dryer fine, washer (front loader Affinity 6000) dead. Electric power there. Day before had no electricity for few hours. Turned out to be that this thing is sensitive to voltage. I have now from 101 to 103 volts and it needs something close to 115. I have almost disassembled it but it was hard to do and no manual on web (except to purchase for $15). So, after removing back paned and few screws from front I have turned my attention to my UPS I have for TV - it sometimes would blink with blue diode (means it is starting). I thought why... Then I have luminescent (energy saver) lamps around house and those are not sensitive to voltage so lights are fine. In bathroom however I have halogens and those seemed dim. This time I have looked at my tester again and noticed that it shows ~101.2 volts. So I am taking UPS from my TV and moving it to laundry, plug UPS to outlet, washer to UPS - washer still dead. I unplug UPS from outlet and washer comes alive...
Hope this helps.
Orest Dmytryshyn
Edmonton, Canada
Posted on Feb 02, 2009
allbrands
  • 600 Answers
SOURCE: where is my pump filter
Hello, you have to disconnect number 41 from the tub and number 40 is the coin trap filter http://lookup.bellparts.com/diagramenlarge/frigidaire/51557/00000370
some guys can do it from the back others have to take the control panel and whole front off to do it. even to do it from the back is not an easy task... hope this helps please rate me thanks :)
Posted on Jun 08, 2011
Why wont my washer to perform the system clean cycle?
Hello Larry Occhipinti, thank you for your post!
If you are pushing the necessary buttons on your Frigidaire washer to perform a system clean and they are not working, it could be a possible issue within the control panel. I would recommend a reset on your appliance which can be done by disconnecting power from your appliance for roughly ten minutes. If that does not correct the issue, you can run a hot water wash cycle with a cup of bleach inside the tub to clean your appliance out as well. I hope this is helpful. -Matt
Aug 31, 2014 | Frigidaire Affinity ATF7000E Front Load...
I have teh atf6000ES1
Pau? as in end of life? seems that perhaps the control board is speaking in a foreign language? anything happen recently to make it this unhappy?
May 23, 2008 | Frigidaire ATF6000ES Front Load Washer
How do you replace the timer on a frigidaire frontload washer
Good Morning Friend,
I understand you are trying to replace the timer on your Frigidaire Affinity washer, model# ATF7000E. If it is just the selector knob you are replacing, you should only have to snap the new knob on. If it is anything other than the selector knob, typically it is not a do it yourself repair. I do suggest contacting your local authorized technician for further assistance. They have been trained on your specific appliance, and will be able to better assist, and replace the timer on your washer. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
shaun
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
No panel lights!
Longer explanation:
Hope this helps.
Orest Dmytryshyn
Edmonton, Canada
Jul 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frontload washer, affinity
you have to take the front lower panel off if it is the piece im thing about if not you have to dig the front off be careful on how you take it apart because it has to go back together the same way good luck
Dec 10, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
94 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
