Question about Garden
Blades won't engage on 42" Troy Built Riding Mower> I believe it is a 1992 model.
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
wadembly
  • 489 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 95 Answers
SOURCE: lawn mower blades won't enage
Go to Sears web site put in your model number and you will find all your info there. http://www.searspartsdirect.com/partsdirect/index.action
Posted on Mar 25, 2010
heres2maine
  • 84 Answers
SOURCE: Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Posted on Apr 15, 2010
richroth
  • 9472 Answers
SOURCE: my troy built 17.5 hp
Take a look at this tip I wrote on the no start problem for your mower. It should help you.
Posted on Oct 18, 2011
My troy built briggs and stratton 22hp riding lawn mower when I engage it makes a clunk sound but the pulleys and blades wont turn
sounds like you have something stuck on the blades. if not check to see if you can turn the blades by hand all the way around. its possible the spindle bearings locked up. (with the engine off)
Jun 14, 2016 | Troy Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
Troy Bilt Kohler 18hp riding mower won't start.
there is a main fuse . usually hidden in the wiring . contact a dealer for assistance
Oct 07, 2017 | Troy Garden
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
Blades wont work on 2004 troy built riding mower
check the belt tension if it has a switch to turn it on check the fuses and see if theres power going to the clutch
May 19, 2012 | Garden
I have Troy Hydrostatic 46" when I attempt to
If you lower the blade deck and get down near the mower, you can see the blades belt on top of the deck. If it is intact, with the engine off, have someone try to engage the blades. A tensioner should move into place to tighten the blades. If it is not, follow the engagement lever to under the dash to see if there is a cable broken or a rod detached.
Post back.
Gary
Sep 11, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
Lawn mower blades won't enage
Mar 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
