Question about Xerox DocuColor 12 Printer
My xerox dc12 is getting a black line through when i have printed over 5 copies what do i need to do
    Champion:
  • 241 Answers
Check that stell rod beside of fuser unit has any black toner just clean that toner
Posted on Oct 05, 2010
What does it mean when a dc12 Xerox print with two faded lines when printing from tray 5 is it a problem with the drum or the belts?
answer # 0034 Drum
You can check the developer 'brush' by taking out the drum and looking at it. check the manual PDF download here.
Note: link take a few minuts before download please wait.
techbelkin
Dec 20, 2010 | Xerox DocuColor 12 Printer
Dc12
Drum Sensore is dirty
Solution
put out first drum & see up side in near ibt belt one sensore (Small Steel Body ) Clear with Alcahol.
Jul 11, 2010 | Xerox DocuColor 12 Color Copier
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
Error 3-380 dc12 system fault any solution
timing patch on ibt dirty....usually! If you take out the copy/print cartridge you will see a black belt at about the 7 o'clock position, its on that. easily fixed your competent with a screwdriver. Let me know if you need more info
Dec 25, 2008 | Xerox DocuColor 12 Color Copier
Printing to a Xerox DC12/DCS50
you can't print via serial to it. You will have to check the settings in your rip to see what the ip address is. Lights will blink all the time to indicate it is on a network, its just not talking to it. Then you go into your add printers section click the + sign and it should come up in there if the ip address is in line with your mac ip
Dec 16, 2008 | Xerox DocuColor 12 Printer
Graininess on xerox dc12 print s
hi i think u took print in low resulution photo. pls check ur phot resulution.
Nov 21, 2008 | Xerox DocuColor 12 Printer
My dc12 don't print good. They print as shadow
If there is a shaddow on the printed documents, then it may be you drum needs replaced in the printer...
Hope this helps.....
Oct 28, 2008 | Xerox DocuColor 12 Printer
Cmyk dots on the print
There are several causes of those.
So go to Xerox.com
Click "support and drives"
then in the product name box, Type DC12
Then any line click support
IN the search box type "spots" and read the relevant solution.
May 05, 2008 | Xerox DocuColor 12 Printer
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
159 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
