Question about HP Pavilion dv1000 Notebook
Start up I have a problem with my HP laptop it was working just fine then i shut it down for about 30 minutes when i came back and tried to start it it told me I should start it in safe mode. So I did after a while it popped up with this blue screen stating that windows has a problem and will shut down to protect my computer, since then i cant get pass the blue screen to log in to my computer any ideas?
  • 81 Answers
Use the Windows Recovery Console to run a check disk repair.
This link explains how to:
Posted on Apr 19, 2008
Samsung dv331ag works fine for 30 minutes then everything goes black after 1 hour works fine again for only 30 minutes
sorry to have to inform you sounds like a bad motor windings? overheating after 20 minutes then shutting down after cool down about an hour it starts agin. A bad venting problem may have caused it?
May 28, 2014 | Samsung DV331AG Gas Dryers
Hp dv7-4165dx caps lock blinking, not powering up
I had the same problem with my HP DV7-4165DX. Here is the solution, although it may sound crazy.
1. Lift open the screen.
2. Take a towel and wrap it around the base of the laptop so no air can escape from the fan.
3. Turn on the laptop and let it get hot for 15-30 minutes.
4. Turn off the laptop.
5. Remove towel and power it back on. The laptop should boot up and go into Windows. This is a temporary fix - once you power it down and let it cool off, it will not turn back on and you will have to repeat the process.
6. While in Windows, you need to update the BIOS to "2013-02-26 , VersionF.29, 4.16M" Here is the link to the application:
7. Run the executable file.
8. The BIOS will ask you to shutdown.
9. When you power the computer back on it will run a program to update the BIOS.
Now, I tried this last night. I turned the computer off before I went to bed and it was cold in the morning. I hit the power button and it started right up. I shut it down and ten minutes later tried it again - it started right up. Hopefully you will have the same success I did.
Sep 28, 2013 | HP Computers & Internet
My HP G60-235DX notebook worked fine.I tried to turn it on the next day and it won't power up.The indicator light turns on but stays red and the screen stay black and windows won't start.Sometimes If I...
Try removing the battery and the power cable for about 30-40 min and then plug it back in. If that doesn't work try contacting HP. I had a similar issue with a Toshiba replaced the HDD and after that it was fine. So I would say try those, if all else fails post on
Jul 11, 2010 | HP G60-235DX Notebook
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Laptop screen goes white
Hi there Try to connect it to an external monitor and see how it goes. If the problem stays, that mean your video chip is probably defective. bad news since it's integrated in the main board. Replacement of this is costly. Unless it's still under waranty of course. If not, that means your inverter is probably defective and needs to be replaced.
Mar 31, 2009 | Toshiba Satellite A135-S2266 Notebook
1999 4.0L Jeep Grand Cherokee shuts down after 20-30 minutes.
I'd suggest the ignition control module, however I'd have a certified mechanic check it out just in case...
Feb 01, 2009 | 1991 Jeep Cherokee Briarwood
I have an HP Pavilion dv2000, it has always worked fine until around April 2008 it started making this whirring noise. It is on and off. Recently I removed the bad battery (went almost dead in about 30...
if it shuts down on it's one.. very like may be the cooling fan on top o fthe processor causing it to overheat... you may want to have that serviced by trained technitians as working on inside a laptop cd and replacing a fan is more critical than replacing a hdd, battery or upgrading/installing memory on your laptop.
Sep 21, 2008 | Computers & Internet
Huge problem Please help me? cant see anything
Reset the laptop. Take out the battery and remove the power cable from the wall socket. Wait 30 seconds and put the battery back in, connect it back to the wall socket and start it up.
Jul 01, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv1000 Notebook Logo
149 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
