Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
My d40 when set on auto at the lens side and i press the shoot button it will not auto focus or click for photo. if I put it in manual at the lens i can shoot photos but they are out of focus. can u suggest anything?
  • 6,826 Answers
Oops, your d40 sounds like it's broken. Did you just buy it?
If so, I would return for a new one.
Posted on Jul 09, 2010
The lens no longer works on auto and as I wear glasses, I can't manually focus it.
Try cleaning the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Sep 20, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
D40 does not shoot on auto mode
on the side of the lens check to be sure it is set to auto and not manual.
Oct 15, 2009 | Nikon D40x Digital Camera
Ive got the nikon d40. when i take photos close up they are blurred. there r 2 settings on the focus lense one is letter a one letter m. you have to move switch to indicate one or other. camara wont take...
The letters you're referencing is the M/A (manual / auto) focus switch. The lens has this switch and operates in Auto Focus mode when set to "A" and manual focus mode when set to "M".
You have to manually focus on the subject when in letter "M". If you do not, the result will be out of focus. From your description, it sounds like the camera / lens combination is attempting to focus and operate the shutter in auto, and focusing in manual; but due to some type of damage resulting from possible mishandling, exposure to dust, dirt or even moisture is interfering with the successful completion of the process.
You could isolate the problem to determine if the cause is in the lens or camera by simply attaching the lens to another compatible Nikon camera or placing a different auto-focus lens on your D40. The problem will either stay with your D40 or follow the lens when attached to a different camera. It is also *possible* that due to numerous attempts of auto-focusing with your D40 & lens combination, that both the lens *and* the camera have been damaged. If the problem is severe enough, the problem in the failed device could cause failure in the otherwise normally working device, too.
You might be best served by contacting Nikon Service & Support below:
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
You also said you lost your manual. You can download the manual for the D40 directly from Nikon in your choice of English, French or Spanish from the link below:
http://support.nikontech.com/app/answers/detail/a_id/14157/session/L3NpZC9YRTgxQVpKag%3D%3D/kw/D40%20manual/p/19%2C334/c/187/r_id/116678/sno/0
Oct 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
EOS 30D is slow to fire.
Are you sure you aren't in the delay setting in drive mode? This camera has 2 delay settings, one for 2 seconds between when you press the shutter and when it takes the photo, and one with 10 seconds delay - often used when you want to be in the photo (e.g. self-portrait or group photo).
If you aren't in the delay mode, then I need to know more about your settings. What shooting mode are you using? What type of photo are you trying to take (portrait, landscape, sports)? Are you shooting indoors, outdoors, bright sunlight, overcast, etc.?
Dec 30, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
Problems taking pictures with nikon d40
Chances are good that it's not your camera, but your lens. In a darker atmosphere, you need a fast lens, meaning you need a lens that has a wide aperture (1.4 to 2.8) I'm guessing you're using a lens thats' 3.5 or larger. (Yes, the larger apertures have the smaller numbers)
If your camera was spending all it's time moving in and out trying to focus, it's probably because there was not enough light for the camera to distinguish a focal point. Same thing happens when you shoot a solid blue sky. No focal point.
Help me understand by telling me what lens you're using and what settings you were using on the camera.
Dec 09, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 autofocus
This happened to me once on a D70... When mounting the lens, make sure it clicks in all the way when turning counterclockwise. Also it may be worthy to note that both the lens AND the camera must be set to autofocus mode ("A" switch set on both lens and cam).
Marky
Nov 25, 2007 | Nikon D40x Digital Camera
Auto focusing problem
Your camera is only compatable with AFS-type lenses because it has no screw-drive motor.  You can only use AFS Nikkors and Sigma HSM lenses (the lens actually has a motor inside).  You were misinformed.  Bring the lens back and ask for a refund. Take that money and purchase a compatable lens somewhere else.
Sep 22, 2007 | Quantaray 500mm/1000mm Preset Telephoto...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
126 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
