Question about Jenn-Air JEC6288AAB Electric Cooktop
Power requirement 220v 20amp -- wire to unit should be 12x3 or 4?
  • 8,197 Answers
If you are running new wire to the cook top. You need to run 10x4 wire. The 12x4 wire is not large enough for the 220v. Also the 20 amp breaker is not large enough to run the cook top. You need to use a duel 30 amp breaker.
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Jul 09, 2010
Power needs for Cooktop
You need to put a multimeter across the two wires to check it.
Mar 09, 2014 | Cooktops
Replacing stove. What to do with blue and yellow wires?
First, please don't do your own electrical work if you are unsure about what you're doing. It's worth it to hire an electrician.
Not sure what the blue and yellow wires could be. The others are standard 220V colors, but that doesn't mean that they are connected the standard way in the panel. If you know how to remove the panel cover and look at the breakers, make sure you do that before you assume anything. If you don't know how, call an electrician.
Assuming the blue and yellow are no longer needed, and that the other four are wired properly, you should disconnect the blue and yellow wires on both ends and remove them if possible. If you can't remove them, you should insulate both ends and mark them as being disconnected.
Oct 02, 2009 | Cooktops
Bake and broil do not work
assuming that the worst case senario has taken place
first thing i would check is ensure i have proper voltage at the outlet, 120 from each side to ground
220 across L1-L2
the elements are the only thing on the range that uses 220v
if you know how to use a mutimeter
you can test both the elements
disconnect the range at teh breaker
take out the screws at the back wall that hold the elements in
pull out about an inch becareful they dont leave much slack on the wires
disconnect on element terminal and apply your leads your looking for continuity, your meter should beep
if not replace the element
if yes, let the element hang ensureing niether terminal touches anything, reconnect the other terminal
now turn the stove on bake if your doing the lower
turn you meter to ac voltage
you should read 220v
anything less than that, your problem is before that
Aug 02, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
How to connect 4 wire into 3 wire existing box.
L1 and L2 connect to the black and red. White connects to White. Green connects to the electrical box if it is made of steel and is grounded. Otherwise the green connects to the whites
Jun 14, 2009 | Jenn-Air JED8230 Electric Cooktop
Keeping existing 220V for oven and getting 110V to cooktop
yes you need a seperate line for the cooktop. whoever hooked your oven and cooktop up in the first place should have never hooked them to the same line to begin with. you are lucky you never had issues.
May 25, 2009 | Thermador SGS36GS Gas Cooktop
Wiring a jec9536bdb cooktop
you need a three wire or two as long as you have the two hots and ground. dont skimp on wire size though. hope this helps
Nov 04, 2008 | Jenn-Air 35 in. JEC9536ADS Electric...
JED8430BD Wiring
from supply
white, black - should be hot then ground
On cooktop
red, black - should be hot white - neutral then ground
If you have a volt meter measure
supply
between white - black 220v
between white or black - ground 110
cooktop
between red - black 220v
between red or black - ground or neutral 110
If the above is confirmed
connect
red (cooktop) to white(supply)
black (cooktop) to black(supply)
white (cooktop) to ground(supply)
Regards
Sep 06, 2008 | Jenn-Air JED8430 Electric Cooktop
Frigidaire electric glass cooktop wiring problem
HEllo
I have the following manuals in PDF format,
I will gladly email them to you.
Model: GLEC30S8ESB Owner Guide(English): 318200612en Wiring Diagram: 318046807 Installation Instructions: 318201426 Parts Manual: 5995479655
Eddie Rentas
Tupper Lake NY
Jul 21, 2008 | Frigidaire 31 in. GLEC30S8 Electric...
Frigidaire smooth cooktop PLEC30S9EC
Smalltree, You may want to make sure that they have 220 wired to the cooktop. I've seen a lot of new construction where they are hooking the cooktops up to 120V and wondering why they're not working. Check this first and post back..Catriver.
Nov 02, 2006 | Frigidaire PLEC30S9EC Stainless Steel...
Jenn-Air JEC6288AAB Electric Cooktop Logo
87 people viewed this question
Top Jenn-Air Cooktops Experts
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
