Question about Gigabyte GA-K8VM800M Motherboard
Can't enter window
Try to format hard drive, cannot even enter the cd even after changing th e boot priority to cd. the system stuck at detecting IDE drive. but can enter BIOS
  • 127 Answers
Check you cables from drives to mother board make sure they are all pushed in tight
and check the jumpers are set properly on all your drives then retry if it deosn't work you might need new motherboard or one o your cd or hard drives is faulty
Posted on Jul 09, 2010
Format aspire4736z
Hi there.
To format you will need:
Operating Systems (OS) CD/DVD
Steps:
1) Enter the BIOS when the laptop boots by pressing the Delete key repeatedly.
2) Once the BIOS is open locate the boot disk priority and set prioity 1 to the CD/DVD drive, set priority 2 to the laptop's hard drive.
3) Save changes to the BIOS and exit. The system should now reboot.
4) Insert your OS CD/DVD.
5) Press Enter when the system asks you if you want to boot from the CD/DVD.
6) The OS setup should now start, the first thing it will ask you to do is format your hard drive.
7) After you drive is formatted you can either continue with the setup and install a fresh copy of the OS or you can exit leaving the main drive clean.
~ Slasher_X
Sep 25, 2011 | Computers & Internet
Cannot install windows xp after formating
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
if you need more help with this or if i have misunderstood the problem
post a reply
hope this helps you
Sep 06, 2011 | Toshiba MK3276GSX 25 inch 320GB 5400RPM...
Cd Group Boot Priority not installed
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
Mar 27, 2011 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
I have IBM thinkcentre 8172. I try to reinstal windows XP. But when the pc restarts, it can't complete the instalation because it can't read from CD. This is not the original DVD/CD rom. When i remove the...
If your CD-Drive is IDE and you have IDE HDD you need to remove or set correctly jumper on the back of CD-Drive. I think by default it's setup to be Master, and HDD also Master, so you need to give somebody Slave priority neither HDD/CD
Apr 19, 2010 | IBM NetVista PC Desktop
It wont load windows xp even with the recovery disc it just keeps saying boot with any key
You may have set the boot priority in the CMOS. If so, enter the CMOS setup and set the priority to "boot from HDD" This may not fix your problem, but it is a start. If it still wants to boot from another source, the HDD master boot record (MBR) is corrupt, or the HDD has failed.
Mar 17, 2010 | Averatec (70-822301-00TRI) (7082230100TRI)...
Barracuda 7200.7
Hello Sir,
While windows is booting first go to BIOS settings by pressing "Del" or "Esc" then change the boot priority that is save the first boot priority as cd-rom and second boot priority as hard drive... so that you can boot you system with bootable cd...
And then while formating the system just delete the partion that is only "c:/" and install the windows in to that and don't even do anything to your "d:/" drive then you can get all your data back... Abd the cd should be bootable format...
Aug 22, 2009 | Seagate Barracuda 7200.7 Hard Drive
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
Pc wont boot up after reformat.
After format your computer will not boot if don't have the Sys files on it. Try to put your hard drive back to your computer and start booting with some cd with hard drive utilities like http://www.ultimatebootcd.com/
Sep 24, 2008 | E-Machines eMachines Desktop PC
I need Help
Hi Banyar, lets check the main menu & the boot order in you're bios. Start up the PC, as soon as you see any display on the monitor press the delete key every 2 seconds until the bios main menu loads. This is also where you can see the time & date. List on the left is;
Primary IDE Master
Primary IDE Slave
Secondary IDE Master
Secondary IDE Slave
Across from these on the right is the matching device. If you have one hard drive the bios will show its model number on the right.
Ex: ST150322A. (You're drive will be different). If you have more than one hard drive the second drive, (Should be listed as Primary IDE Slave). CD-ROM drives would be listed as, Secondary IDE Master & Secondary IDE Slave. Write down the model name of the Primary IDE Master on paper. Now go to the title, "Boot" in the bios. Use you're manual & go to page 2-25. High-light, Boot Device Priority & press enter. Set the order as shown in the manual. Make sure the 3rd boot device is set to the correct hard drive listed from the main menu. The model you wrote down. Once set save & exit the bios. The PC will restart. You should no longer receive the error message & windows should boot normally. If windows does not load normally than it is possible that the Primary IDE master drive is not the drive with windows installed on it. You must find the correct drive with windows loaded on it. Connect that drive to the Primary IDE master port.
You may need to reset the drive’s pin settings so it is seen as the primary drive.
Than change the 3rd device in the bios boot priority list with the correct drive. Windows demands that the operating system be located on the, Primary IDE master port. Please read pages 2-12 & the top of 2-13 in you're manual.
More questions? Post them here.
Good Luck!
Mike
Jun 21, 2008 | ASUS P5VD2-MX SE Motherboard
Gigabyte GA-K8VM800M Motherboard Logo
54 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
