Question about Bosch Axxis WTA4400 Dryers
Dryer runs but no heat and clothes stay wet and cold
  • Bosch Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
rickzilla
  • 706 Answers
SOURCE: MAYTAG GAS DRYER TUMBLES BUT NO HEAT (FRONT LOADER 6 YRS. OLD)
Hello maryfitgera,
It certainly sounds like you are not getting a flame established in your dryer. That can be one of several components such as a non-resettable thermal fuse, gas valve assembly or control relay to that gas valve assembly. Unless you are well versed on how to work on these kinds of components, I suggest you just call in an appliance tech or.. let me know if you want to attempt diagnosing and repairing it yourself. Be advised that there are elements of danger in so doing. Let me know how you want to procede on this and I'd be happy to walk you thru it..
Regards,
Rick
Posted on Nov 24, 2008
danromarris
  • 101 Answers
SOURCE: Maytag Atlantis MDE6200AYW will run, but no heat
Check to make sure that you have the proper voltage running to the dryer first. Next you may have a problem with your heating element or with your thermal fuse. Get your dryer opened up so you can see your heating element. Run the dryer and if you see the heating element come on and then turn right back off again then you have a bad thermal fuse. If it doesn't come on at all though then the heating element is bad. Both parts can be picked up at your local appliance repair shop. Just make sure to unplug the dryer before replacing the part. If you have any other questions let me know and let me know if this was helpful for you. Good luck.
Posted on Jan 22, 2009
  • 221 Answers
SOURCE: Dryer puts out heat, but clothes are still wet
There may be a clog underneath the lint trap or the exhaust vent may be clogged, if either fails try changing temperature knob to a different setting.
Posted on Mar 09, 2009
  • 207 Answers
SOURCE: dryer is not drying the clothes
First use the dryers service mode and see what trouble code you are receiving.
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
Once you have the trouble code, let me know and I can guide you from there.
Posted on Apr 16, 2009
  • 45 Answers
SOURCE: Dryer not heating up - Amana Model # ALG643RBW
Heating element
Posted on Apr 28, 2010
Kenmore model 90 dryer electric will dry the clothes takes a long time. Leaves the floor surrounding the dryer damp actually wet just not puddled
Are the clothes wet AND hot? If so - check the exhaust / vent hose for kinks or obstructions. That includes the cap / flap on the outside of the house.
If the clothes are wet AND cold, then the electric heating element isn't heating likely due to a broken or poor electrical connection, burned out heating element, defective thermostat, etc..
Jul 14, 2015 | Kenmore Dryers
My dryer stopped heating. Help!
Heating element sounds like its gone out
May 21, 2013 | Dryers
I came home and my dryer had still been running for the whole time I was gone, about 4 hrs. The clothes inside were cold and not dry. This morning I tried getting it to work, but the clothes remained...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 23, 2011 | Roper Dryers
I have a Kenmore 500 series dryer, model number 110.79522800 that will note completely dry clothes. It seems like it doesn't run long enough, heat high enough or a combination of both. What can I do to...
Your Sensor that senses the clothes are wet or dry is shorted out. The dryer works likes this so the dryer heaters dont stay on while the clothes are dry. When the sensor senses the clothes are damp or wet, the heater stays on, when they start drying the sensor senses it and starts to turn down the heaters
http://tlc.howstuffworks.com/home/dryer6.htm
Mar 10, 2011 | Dryers
My gas dryer the heat cycles on & off
clothes not drying, but dryer runs & heats?
1.defective thermostat-----replace
2.fan or it's pully loose on shaft----tighten set screw
3.incorrect heat or timer setting---reset timer
4.clothes to wet to when placed in machine
5.clogged lint screen or duct---clean out
Jul 29, 2010 | Roper RGS7646KQ Gas Dryer
Wet and cold clothes after cycle
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 31, 2010 | Kenmore 72062 Gas Dryer
Making a lot of noise, heats up but the clothes stay wet
DRYER HEATS UP AN CLOTHE FEELS HUMID,,,,,,YOU GOT BAD COILS......HEAT IS NOT CONSTANT..POWER TO THE COILS DROP AN THEN COMES BACK UR MAGNETIC COILS ARE BAD
YOU NEED NEW DRYER COILS
May 28, 2009 | Maytag Dryers
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dryer spins but no hot air comes out
check the fuses.one runs and other heats it.might be a wire burnt off in the back or on the motor
Mar 17, 2008 | Dryers
Bosch Axxis WTA4400 Dryers Logo
116 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
