Question about Garden
Husqvarna 2448 rider. ran good till i went to use it thursday,no start ignition has no power to it changed clutch switch and solenoid.seat switch checks out ok whats gong on? Is there a fuse somewhere pls, help Thanks
  • 6,826 Answers
Nice mower.
We have a Husqvarna from Lowe's that we bought used but it never has given us trouble. The only thing you didn't mention is the battery. How are the connections to that (I know that's sort of basic).
Posted on Jul 09, 2010
  • 3 more comments
  • Mark Gelardi Jul 09, 2010
    Terminals are all good,is there a fuse somewhere on this unit??
    Are you there???
  • Duane Wong
    Duane Wong Jul 09, 2010
    I'm sure there is, but never had to change one to know exactly where it is on this particular mower.
    I know, on my 1984 Craftsman mower, there's a pigtail under the hood that has a fuse that was giving me trouble.
    Everything was dead until I wiggled it, removed it, cleaned it, bent it, and put it back in. The socket was kind of melted as far as the plastic but still functions, so I didn't bother replacing the socket.
  • Duane Wong
    There is a fuse on part #26.
    You can look at the .pdf at husqvarna.com.
    http://www.husqvarna.com/us/homeowner/su...
    TRACTOR - MODEL NO. 917.279260 (GTH2448T), PRODUCT NO. 960 43 00-09
    ELECTRICAL
    KEY PART
    NO. NO. DESCRIPTION
    1 532 14 49-27 Battery
    2 874 76 04-12 Bolt Hex Hd 1/4-20 unc x 3/4
    8 532 18 64-91 Battery Box
    16 532 17 61-38 Switch Interlock
    21 532 18 37-59 Harness Socket Light
    22 532 00 41-52 Bulb, Light # 1156
    24 532 40 02-53 Cable Battery
    25 532 19 88-93 Cable Starter
    26 532 17 51-58 Fuse
    27 873 51 04-00 Nut Keps Hex 1/4-20 unc
    28 532 14 54-91 Cable Ground 21" Blk 6 Ga.
    29 532 40 15-45 Switch Seat
    30 532 19 33-50 Switch Ign
    33 532 14 04-01 Key Ign Molded Generic
    34 532 11 07-12 Switch Light/Reset
    40 532 40 11-05 Harness Ign
    41 871 72 04-08 Screw Thd Cut 1/4-20 x 1/2
    42 532 13 15-63 Cover Terminal Red
    43 532 19 25-07 Solenoid
    46 532 19 81-38 Gauge Hourmeter
    50 532 17 46-51 Switch PTO
    55 817 49 05-12 Screw Thdrol 5/16-18 x 3/4
    59 532 40 03-03 Outlet 12-Volt
    71 532 19 42-76 Harness Ign. Dash
    90 532 40 07-24 Cover Terminal Battery
    91 532 19 02-70 Strap Battery
    92 532 19 66-15 Harness Pigtail Consle ROS
    93 532 19 25-40 Screw Plastite 10-14 x 2.0
    94 532 19 18-34 Module Reverse ROS
    99 817 67 04-12 Screw Hexwsh Thdrol 1/4-20 x 3/4
    100 819 09 14-16 Washer 9/32 x 7/8 x 16 Ga.
    NOTE:
    All component dimensions given in U.S. inches
    1 inch = 25.4 mm
    30
  • Duane Wong
    The above link goes to the Husqvarna.com site for the 2448 and shows a fuse part no. 26.
    There's an exploded view on the .pdf. and parts list.
    It appears it is like my Craftsman, with a pigtail under the hood where the fuse is located.
Why does my husqvarna 2448 die when blade engages
I agree with Phil. The safety switch under the seat on my Husqvarna is very sensitive. Sometimes if I hit a large enough bump, it's enough to disengage the switch even with me on the seat.
Jun 20, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna YTH 2448 shuts off when I let out clutch or engagae mower blades
Hi, check or replace the switch on the seat, basically its not telling the safety system that you are on the seat. Regards Phil.
Jul 07, 2012 | Husqvarna Garden
Husqvarna yth 2448 shuts of when i let the cluch out, same thing when I engagge mower blades
check the safety switches start with the one on the clutch it is a double switch
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
Intermittent starting problem
hav e you checked the brake/ clutch safty switch . you said you looked for the clutch switch not sure if your talking bout the clutch that some models use to engauge the mower deck or if your taking bout the brake/ clutch switch .. either one will cause the rider not to start . your brake/clutch safty switch should be located on the under side of the rider just inside the frame rails very near the brake rod that the brake / clutch pedal is part of .. this is usually a 3 inch or so spring loaded piece usually white in color and will have a piece sticking out if the brake is depressed . " if i remember correctly " . check there these on some are on the same side as the brake / clutch pedal others are on the other side of the rider . i cant remember off the top of my head what side craftsman riders are on for sure .. you cna try to take this off and use electrical contact cleaner on it to clean the terminals in side it , this can be bought from any auto parts store like autozone or napa .. also check your battery i have seen some batteries cause the same issue . you can check the battery by checking the power it has under load with a volt meter set to amps and see what it drops down to ... also another tirck is if you have a battery jump pack also known as jump starters , hook one or even a battery charger to the battery ( charger on 12volt low ) and see if you still have the same starting issue .... last idea is you could have a bad ignition switch after all and its not sending power out every time , i had a issue with my gt where my head lights didnt work and changed out the switch n they work now .. . hope these ideas help if you need any more help just drop me a line ill help best i can ..
Nov 27, 2011 | Craftsman Garden
I have a yard machines 46 inch cut 18.5 hp riding mower that wont start. i changed ignition swith and soleniod. if i cross wires on solenoid it will start after putting gas in carb. it runs till gas runs...
I would start with the safty switches. Look for them on the deck engager, seat??, break/clutch pedel,blade engager lever. Remember the blade sw. must be disengaged be fore it will start. Ifit runs as you said It is in the wiring/ electrical system. I know it is not in the ignition sw. or seloniod. szm230
Apr 15, 2011 | Yard Machines Garden
I have a 6 year old Craftsman rider, model 27363 w/18.5 HP Briggs engine and 42'' deck. I tried to start but nothing - no click, ammeter doesn't move, hour meter doesn't run. Checked battery, have 12.8...
The start circuit usually only goes through the clutch/brake switch, and the clutch switch. That way it won't start if the clutch isn't depessed (brake on) and the mower deck turned off. You can test for voltage on the s terminal (start) on your switch. then for 12V+ at the clutch brake switch, then at the clutch switch, finally at the solonoid. The seat switch usually only kills the ignition if you have the PTO engaged, and you leave the seat.
Jul 26, 2010 | Craftsman Garden
I have a husqvarna yth2148 and the blades have quit and then after sitting till the next day they have started working and now it quit completely and wondering if there is a way to test the pto switch by...
Testing the PTO clutch and wiring.
1) A voltmeter or test light is a MUST.
2) Starting at the clutch, there is a connector from the wiring harness.
a) one wire will have voltage, the other is a ground wire
**NOTE: a person must be in the seat, pto turned on. DO NOT start the engine, but have the key in the run position as if you were mowing.
If there is voltage in the wiring harness connector, the problem is the clutch assembly.
If NOT, then
3) check for voltage from the back of the pto switch (normally, the switch can be removed by depressing the holding tabs on it's sides, so that you can access wires easily)
a) you will have a supply wire from the ignition switch, and a wire that goes to the clutch harness. with the switch on, you should have voltage on at least 2 wires. The other wires are the seat safety/start circuit and are not part of this test.
b) If you have battery voltage coming into the switch, but nothing coming out, the switch is bad.
c) if you do not have any voltage supply, then
4) check the ignition switch, does it have a battery source voltage, and in the run position, it normally will have an 'A' terminal that supplies the pto switch
* note
5) many times the internal terminals of the igniton switch can fail to supply voltage to the pto switch
** I am assuming the supply to the ignition switch is good, because otherwise you would not be able to start the tractor..
Nov 10, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna 2448 pto switch kills engine,bldes
try unplugging the pto, start the mower, then engage the pto switch. If the fuse still blows trouble is somewhere in the mowers wiring if not the ploblem lies in the pto. hope this helps
Jul 15, 2009 | Husqvarna Garden
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
