Question about Acer Aspire One 532h2298 Netbook
Battery indicator always red
Battery always shows 87%
  • 127 Answers
Take battery out blow where the battery was to make sure no dust in it then put battery back in make sure it clicks into place if that doesn't work you might need to replace your battery or your charger could be faulty
Posted on Jul 09, 2010
2006 Passat 3.6 Relay J271 ECU Location Look Everywhere But Cant Seem To Locate
if there is no legend on the relay cluster cover makes it very hard to locate
J271 varies from model to model, but once you have the relay out, check one of its sides for the diagram of the pin outs. The solenoid 12V supply will always be marked as 85, the negative always as 86, the normally open (N/O) contact as 87, the normally closed (N/C) as 87a and the pin marked 30 is always the switching voltage supply. Notice that terminals of 87 and 30 are always larger than the other terminals. Connect the relay solenoid to a battery with clip leads and measure the voltage at 87 and 87a, and that it changes over when you hear the relay click. Alternatively do a continuity test between pin 30 and 87, then again between 30 and 87a. Then connect power to the solenoid and the continuity measurement should switch over to the other pin. Unlike the image above, there may be even be more than 1 double pole double throw switch contacts on the relay depending on the model of your car. The Audi J271 is different to some VW's and has more terminals.
just look at the way VW put relay clusters into a passat ..what a mess
Oct 27, 2016 | Cars & Trucks
Checking tbi injecter voltage
On a 1988 model which should be the same as 87, I show two injectors in the throttle body. Inj 1 has red and blue wires and inj 2 has green and white wires.
The red and white wires should be battery voltage, and the other two are ground signal wires from the computer.
Dec 20, 2012 | Chevrolet Silverado 2500 Cars & Trucks
I replaced the battery on my 87 yamaha moto 4 80cc and don't remember which wires go where , there is 3 of them
Assuming you have red and black wires
Red to positive +
Black to negative -
Nov 03, 2012 | Motorcycles
Replaced computer but still cant get spark.
If you turn the key on and do not hear the fuel pump run at all after you have replaced the computer then i would look at the (ASD) relay (auto shutdown relay) for the problem. Remove the relay from the power panel. To test the relay,use a ohm meter and connect one end to the #85 and the other end to #86, the resistance should be between 70/80 ohms. Then check continuity between terminals #30 and #87a. The meter should indicate continuity. Then check for continuity between #30 and #87, the meter should not show any continuity. Then connect a jumper wire to terminal #85 and negative post on battery and connect the other jumper to terminal #86 to the positive post of battery. By doing this it will energize the relay and during this time connect the ohm meter between #30 and #87. This should show continuity. If not replace the relay. Hope this will help you.
May 24, 2010 | 1994 Dodge Grand Caravan
Power problem
Seeing as you notice that your battery life is half, this most likely means your battery is no longer able to hold a charge, or a full charge. It could also mean the battery is defective.
If your laptop is still under warranty, the manufacturer may replace it. If not, you'll have to buy a new battery, unless you always keep it plugged in anyways.
Mar 23, 2009 | Dell Inspiron 600M Notebook
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Panasonic lumixDMC-FX7 camera
Could be either. If on switch on again the indicator is full and you get more work done then its a camera fault. If when you switch on again the battery remains flat then this could be the camera fault too the flash capacitor showing signs of distress. On the other hansd the battery could be nearing the end it useful life. How much is a new battery?
Aug 29, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
Battery indicator light blinks red
if it show fully battery also when u charge your battery it show from the red indicate only tht is not a problem... u need to charge the battery fully ... untill the msg shown as charge complet .. so need not to worry about the Red blinking battery indicator when you plug in charger.
Apr 28, 2007 | Motorola Mobility RAZR V3
Acer Aspire One 532h2298 Netbook Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
