Question about Whirlpool ACQ158XP Wall/Window Air Conditioner
Fan not working; no cooling
Can turn unit on; motor runs for a few minutes, but no air movement. Compressor doesn't appear to be functioning. How much to repair this unit?
  • Whirlpool Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
Refrigerator and freezer doesn't keep food as cold anymore. Food is spoiled and temperature is at it's highest. Whirlpool w8txngfwt
Get a repair man to check out the freon pressure in your unit. If the freon is low there will be no cooling power. Ours had a little leak in a hose and cost $95.00 to repair. If it's an older fridge it might be better to purchase a newer one. Unless you have the testers and know what you are doing to check this unit you need a repair man.
Aug 24, 2016 | Whirlpool Refrigerators
Haier HWR06XC9 fan stopped working
Either the fan motor
the fan control relay
or the fan control relay switching transistor
the unit is re starting because the gas is not getting cooled
If competent check for voltage at the fan and work you way back
Apr 14, 2014 | Haier HWR06XC9 Air Conditioner
Coleman Rooftop AC fan stops after 7 or 8 minutes of running. Will turn on again after about 10 minutes on its own.
Remove green (fan run) wire from thermostat, and connect to red wire (power) and see if fan runs, and if it will stay running. That will by-pass thermostat to see if it is problem. If it continues to run, thermostat is problem. If that doesn't cure it, I'd remove cover up top and with power off at circuit breaker, blow compressed air in to motor air holes to make sure it's getting proper air for cooling, as well look for small plastic plug on housing where oil can be added ( few drops) to lubricate motor. Leave cover off and try fan to see if that may help. If at all possible, a clamp on amp meter will confirm if motor or relay is at fault if none of these suggestions help. If amp draw at motor too much, motor may be seizing when warmed up from running. test draw when first started and after running for amount of time that it usually quits, and if noticeable difference, motor is seizing and needs replace. You can also test amp draw at main 120v feed wiring with unit just in fan mode.
Sep 13, 2012 | Coleman Heating & Cooling
Hello. I have a Bryant 561CJ030-D AC unit. The fan comes on but doesn't seem to be cooling. We have had record high temps the past couple of weeks (over 100 degrees), and I'm wondering if the...
Is the compressor turning on? The fan may be running, but you will not get cooling effect unless the compressor is circulating refrigerant. It appears your unit is a 2.5 ton unit. What is the square footage of the space being cooled? Is the space insulated?
Aug 04, 2011 | Heating & Cooling
I have a RUUD central air conditioning system, model NBHC-18J20SFA. The cooling function is not working. The fan on the outdoor unit is not working. When switching to COOL, the compressor works for a few...
sounds like the outdoor fan motor and/or capacitor needs replaced. The compressor will run for a short time because the fan is not pulling the heat out of the system, it can cause damage to the compressor if the fan is not repaired, Ruud used a 3uf capacitor rating for the outdoor fan motor, if the motor has been changed make sure the proper capacitor is also changed for the new motor rating.
Jul 05, 2011 | Ruud UBHC Air Conditioner
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 06, 2009 | Dometic Rooftop RV Air Conditioner
AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Jun 08, 2008 | Goodman CLQ36AR49 Air Conditioner
Whirlpool ACQ158XP Wall/Window Air Conditioner Logo
144 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
