Question about Samsung ML 2010 Laser Printer
I just used my Samsung printer to print a document. It got stuck toward the end and did not come out. As a result I pulled the paper out and now the On line/error light is red. I've tried turning the printer off and then back on opening/closing the front as well as the area on the top but it is still red. Please help. Thanks!
  • 127 Answers
There might be some more paper jammed indside printer check to make sure all of the paper is out
Posted on Jul 09, 2010
Printer eror code U051
Instructions
    • 1
      Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
    • 2
      Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
    • 3
      Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
    • 4
      Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
    • 5
      Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
    • 6
      Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
    • 7
      Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
Mar 07, 2012 | Canon MX700 Office All-In-One InkJet...
Code error 5100
  • 1.
  • Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
  • 2 Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
  • 3 Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
  • 4 Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
  • 5 Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
  • 6 Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
  • 7 Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
May 20, 2011 | Canon Office Equipment & Supplies
I have paper stack in my Brother HL2140 laser printer, how I take the paper?
Hi cillacp,
Ok, firstly some may say turn off the printer before removing the paper, but I find it easier with the printer on. (hopefully you know abit about electrical dangers :) This is because when you start pulling the paper the printer will automatically rotate to help get the paper out.
Ok the mistake many people make when dealing with a paper jam, is they try and pull the paper out from the wrong end. You should therefore open the cap of the printer, (same cap where you change the toner, or sometimes you can open the back of the printer). then pull, preferabble using two tweezers, one on each end of the paper towards where the paper would go if it were printing normally. i.e. pull towards the exit of the paper if printing.
Hope this helps abit.
kc
Feb 19, 2011 | Brother HL 2140 Laser Printer
When the cartridges move to the right there is a hang up of some sort and then error 5100 comes up
Error code 5100 describes a physical problem either with a paper jam or an incorrectly seated ink ink.
  • 1
    Check the paper feed tray on the front end of the printer to see if there is any paper visibly stuck inside the printer.
  • 2
  • 3
  • 4
  • 5
  • 6
    Repeat the process with the other ink tanks, and then close the printer's cover. Power the printer off and then back on again.
  • Feb 01, 2011 | Canon PIXMA MX310 All-In-One Printer
    How to fix error code 5100 for canon ip6320D. it appearing while head cleaning.
    This is either due to a physical error caused by a paper jam, or incorrectly seated ink. To fix:
    Jan 21, 2011 | Canon Office Equipment & Supplies
    Message says no paper in front tray. Paper is where I've always put it in back. Won't print.
    go print -> properties -> page setup -> print options -> tick Disable the paper source setting of the application software -> hit ok and go back to "main" -> select the paper source that you want and hit ok ok and print
    Nov 20, 2010 | Canon PIXMA MX700 All-In-One InkJet...
    I received error code 5100.
  • Check the paper feed tray on the front end of the Canon to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
  • Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
  • Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
  • Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
  • Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated
  • Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again
  • Oct 11, 2010 | Canon Office Equipment & Supplies
    Paper is stuck. All cords are correctly attached. What should I do?
  • Step 1
  • Open the front panel of the printer. Look to see if the jammed paper is visible.
  • Step 2 Pull the paper if you see it. Pull gently so you do not damage any other part of the printer.
  • Step 3 Open the next panel. This panel is usually found below the already-open panel.
  • Step 4 Pull the paper if you see it. Again, do so gently.
  • Step 5 Open the next panel. This panel can be found towards the back.
  • Step 6 Pull the paper gently if you can see it. Continue to open any remaining panels, and then remove the toner cartridge.
  • Step 7 Look for the paper by taking out all removable parts. If you still cannot find the paper, replace everything and attempt to restart the printer.
  • Step 8 Once you have removed the paper, restart the printer. You will have to print your document again.
  • Read more: How to Clear a Paper Jam on a Laser Printer | eHow.com http://www.ehow.com/how_2006054_clear-jam-laser.html#ixzz0uOCeh3UK Hope it helps.
    Jul 22, 2010 | Samsung CLP 300 Laser Printer
    How can i remove the paper inside the printer
    For the paper jam issue turn around the printer and open the back door to pull the paper.
    and for the power issue unplug power cord from wall and from the printer side too,plug everything back and ready to work.
    Aug 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Carriage jam error
    Here is the document that i want you to follow exactly in order to resolve your issue.
    CLICK HERE TO VIEW THE DOCUMENT.==>> DOCUMENT
    Please let me know the result after following the document.
    Thank you so much. I remain.
    adonscott
    Jul 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
    Samsung ML 2010 Laser Printer Logo
    116 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    CheckitRight
    CheckitRight
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
