Question about Jenn-Air JCD2389G Side by Side Refrigerator
The refridgerator is warm (60 degrees F) even though set at the coldest setting, The freezer works fine (20 degrees F).
  • rhergert Jul 09, 2010
    The answer does not tell what is wrong or provide possibole solutions.
  • 677 Answers
DEFROST Defrost can be the cause for your refrigerator not cooling problem. To check to see if you have a defrost problem, look in the freezer to see if there is ice build up on the evaporator cover. (The evaporator covers are either in the back of the freezer or on the bottom of the freezer).
Below is a picture of what the coils will look like if there is a defrost problem. Notice how the entire coil is wrapped up with frost.
If there is ice build up click here. refrigerator not cooling If not, keep reading on.
FANS NOT RUNNING
Fans not running will cause the fresh food and the freezer sections not to work. If the condenser fan (the one under refrigerator) is not working, the compressor will cut off on the overload. If the evaporator fan is not running, there will be no airflow to the freezer or the refrigerator. First walk up to the refrigerator and listen to see if the fans (one in the freezer on one under the bottom) are running. If one is running and the other is not then get to the one that is not running and see if something is blocking it. If there is nothing blocking it then replace it. (Note that some refrigerators cut off the fan inside the freezer when you open the door so be sure that the door switch is depressed when performing this test). Refrigerator fan motors can be purchased at AppliancePartsPros.com or simply search your part above.
Top-freezer Leaking/Refrigerator Not Cooling
On a top-freezer when the drain stops up water will back up turning to ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool. You will also see a water leak inside the fresh food section. To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle, I have even used the water hose. Once the drain is clear, mix water and baking soda and pour it down the drain to prevent this from happening again anytime soon.
DIRTY CONDENSER
Dirty condenser can be the cause for your refrigerator not cooling problem.. If the condenser is dirty, the compressor will cut off on the overload. (A thermostat that is on the side of the compressor that cuts it off if it overheats). Often when this happens you’ll hear a clicking noise about 2 to 3 minutes apart. This is your compressor cutting in and out as it overheats and cools off. Now you need to find out why the compressor is overheating. First you’re going to need to remove the cover from the back of the refrigerator. Once you remove the cover you should see the compressor. Now look at the condensing coils (condensing coils are going to be either behind the compressor, beside the compressor or on the back of the refrigerator) to see if they are dirty if so clean them. To clean the condenser I normally use a brush made for this. You can buy them at Wal-Mart. Once clean your problem may be fixed. Leave refrigerator unplugged for a while (20 min. or so). Then plug it back in and if the compressor doesn’t overheat problem is fixed. If it still overheats read on.
START RELAY (Compressor clicking won’t start)
The start relay can also cause the fresh food and the freezer sections not to work. If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Then take the cover off that is on the side of the compressor. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing). Refrigerator start relays can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 or simply search your part above.
STUCK IN DEFROST
If your refrigerator is stuck in defrost, this can be the cause for your refrigerator not cooling problem. Just simply turn the defrost timer a ¼ turn. Defrost timers are normally located in the fresh food section near the controls or at bottom behind kick plate. If the refrigerator comes on replace timer. If your refrigerator is newer, the timer may be electronic; therefore, you can’t do this. But it can still be your problem, although I haven’t seen this often. Refrigerator defrost controls can be purchased at or simply search your part above.
COLD CONTROL
The cold control can be the cause for your refrigerator not cooling problem. This is the least likely of all the problems but happens sometimes. Turn the control up all the way and tap on it. If the refrigerator comes on then replace cold control. If it still doesn’t come on, it may still be bad. You can check it by first unplugging the refrigerator and taking the control out and test it with an.
ohmmeter Unplug the wires and see if you have continuity between the terminals, if not replace control. Refrigerator cold controls can be purchased at or simply search your part above.
MAIN CONTROL BOARD
Some newer refrigerators have a main control board and this can be the cause for your refrigerator not cooling problem. This can be hard to diagnose if you don’t have a wiring diagram or don’t know how read one. I can’t help you because I would need a wiring diagram of your refrigerator to diagnose a main board. Refrigerator main boards can be purchased at
STILL HAVEN'T FOUND PROBLEM
If you still haven’t found the cause for your refrigerator not cooling then it could be a few other problems. One is that it’s a possibility you may have left the door open. If you know you didn’t do that then the door gasket may be bad but this is a stretch because it would have to be pretty bad to cause the fresh foods and freezer sections not to cool. It may be a sealed system problem in which case you’ll need to call a repairman.
Posted on Jul 09, 2010
  • 6,826 Answers
Sounds like the thermostatic computer might be bad, or a bad sensor for temperature in the refrigerator side.
If the freezer works, then it's not the compressor or refrigerant low.
We just got a new refrigerator from Amana that works fine, except that the light sometimes won't go on when the compressor cycles. Strange. These new refrigerators are kind of mysterious compared to the old ones.
But, what are you going to do? They're microprocessor controlled nowadays.
We also have a Jenn Air electric stove/oven from the 1980s which works fine except for the mechanical clock that stopped long ago. lol.
I would call up Jenn-Air for an authorized repair center for your JCD2389G side by side refrigerator.
When I looked at Partstore.com, for your refrigerator there were different letters after the JCD2389G for selecting parts.
Hopefully, your refrigerator is still under warranty, in which case, you should be able to have a repair man come out and fix the problem for you.
Usually, these microprocessor controlled refrigerators are more reliable than the older style ones.
Good luck to you.
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
Tfx24zr refrigerator running 20 degrees warm
It could be freezing up in the freezer part of the fridge, or you may need to add coolant or freeon.
Apr 11, 2013 | GE Refrigerators
Refridgerator is warm, freezer is freezing
Defrost problem. Most likely the defrost heater or defrost thermostat.
Jul 02, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator too warm on coldest setting
The refrigerator coos from the bleed over from the freezer, See if the fan in the freezer is working properly and the crossover duct/vet is not obstructed or close.. Ck to make sure the control in the fridge is working,
Nov 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frig too warm, freezer works great, but frost on back wall
It sounds like the fridge is not going through the defrost cylce due to a faulty defrost thermostat.
Aug 29, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Sep 03, 2006 | Maytag MZD2768G Side by Side Refrigerator
Jenn-Air JCD2389G Side by Side Refrigerator Logo
117 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
