Question about Tools & Hardware - Others
Need a kit o*** rubber O rings but not sure what year model it is.cheers.
  • 127 Answers
Best advice would be go to your local diy store or power tool store and see i they have any
Posted on Jul 09, 2010
I need an O ring for the gas tank
Make sure that you get an o ring with rubber composition impervious to gasolene.
Jun 12, 2017 | Cars & Trucks
Valve repair kit for Schroedahl leak-off valve
Usually, the rubber gasket parts had become brittle. Just replace these parts and the entire component is now "refurbished" and good to go for another 5 years.
Nov 12, 2013 | Valve Repair Kit
The rubber belts on my sony cassette deck(TC-W380) are worn out and i need replacements.Does anyone know where i can purchase them?
Ive used o-rings from home depot with no issues before....I did a little research and the part numbers match to
http://www.ebay.com/itm/SONY-TC-WR665-WR670-WR690-WR701ES-Double-Cassette-Belt-Kit-GTD-5-YEARS-/140828351357?pt=US_Home_Audio_Cassette_Decks&hash=item20ca061b7d
I would investigate on your own to make sure, but the parts cross referenced
Aug 20, 2012 | Sony Dual-Deck Cassette Player/Recorder...
Tee between carbs is leaking on 1997 750 nighthawk
If the "T" is broken the new "T" will come with o-rings to seal it into the carburetors. If the o-rings are all that is leaking, Honda only sells the o-rings in the "T" kit or in the carburetor o-ring kit (either the "T" kit or the carburetor gasket kit will probably run of minimum $50 per carburetor or more ). If all you need are the o-rings , find a dealer that stocks the K&L generic carburetor o-ring kit. You should be able to pick out the o-rings you need for about $1 each (you will need at least two up to six depending on how many tubes run between the carburetors). If you are dealing with one of Honda's tubular rubber "T"s , then you will just have to spend the cash for a new one. The procedure involves removing the carburetor rack and carefully separating the two leaking carburetors so you can insert the new "T" or replace the o-rings. If there are more tubes than just the "T", be sure you replace all the o-rings so you do not have new leaks after reassembly.
Jan 06, 2011 | 1997 Honda CB 750 Nighthawk
I have an Excell model XR2600 pressure washer that will not start. I have had it stored for 3 years. I drained the gas tank and carb and put in fresh gas. Is there a fuel shutoff on this model ? It has a...
If it's been sitting for 3 years most likely the carb is gummed up. If it's getting spark, you could try a small shot of starting fluid into the carb. If it runs on this you know it's a fuel problem. Best bet would get all the MOTOR data, and buy a carb kit from you local lawn and garden equipment parts supplier. . Remove carburator and clean and install kit. Use sta-bil when you put it away next time, but even that only works about a year or so.
Jul 05, 2010 | Karcher 2500 PSI Pressure Washer
Leaking bathroom faucet
These single handle faucets tend to need the internal "O - rings" changed every couple of years. Find your model # and take it to Home Depot or Lowes or some similar store and find the "kit" compatible with your faucet. Some kits have a cartridge, some have springs, O - rings, etc. The kit will have instructions on how to remove tha old one and install the new one.
May 24, 2010 | Delta Model 470: Signature Kitchen...
I have a Moen kitchen faucet, model 87511, that leaks around the insert that the aerator screws on. can I remove it? How? Is there an ''O'' ring that can be replaced? Fred Winker
Unscrew the retaining ring that holds the aerator and "O" ring. Note the O ring may be made out of brass or rubber. If brass it must be inserted with the beveled edge "in" Replace the retaining ring, sealing the threads with a small amout of plumbers putty or teflon tape. You can get a a repair kit which contains everthing you'll need for a couple of bucks at most hardware stores.
Mar 11, 2010 | Plumbing
How to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
Tools & Hardware - Others Logo
27 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
