Question about Bernina BERNETTE 65 Mechanical Sewing Machine
Repairing/Replacing motor on Bernina Record 530 Sewing Machine
I believe the Bernina's motor is worn out. It sews but at a painfully slow speed is smelly and heats up within a few minutes. (my mother was a professional dressmaker and used it extensively since bought new in 1957). Would re-wiring the motor fix the problem or should I look at replacing it. If replacement is the best option what model Berninas would have compatible motors? It is knee-controlled. Thanks for your assistance.
SOURCE: i need a bernina sewing machine manual
Sewing Educational Warehouse provided a very similar manual. Thanks for trying
Posted on Mar 23, 2009
Mimito7
  • 128 Answers
SOURCE: user manual download bernina activa 140 sewing machine
Try this... www.2instructions.com
Posted on Apr 30, 2009
SOURCE: My Bernina 730 record can only run the zig-zag
Sewing machines needs full service now and then (every 10 years will often do). The motor on the 730 series is actually as powerful as they get on domestic machines, and handles just about everything that fits under the pressure foot. Only if the machine has been used a lot over the years are the brushes worn down, but it might need new grease not matter how little it has been used.
However, the stitch applications can sort of gum or clog up if the machine has not been used for ages. Take a look in the manual and oil ever point suggested every time you take out the machine. Try them now and then on slow speed, that might get every function to run smoothly again.
This is as good a machine as any out there, favorably compared to any new machine under 500£. It sews perfect stitches on just about any material, and is well worth a full professional service (At a shop they will always recommend a new machine they want to sell you). All kinds of pressure feet and accessories are available in regular sewing shops and online.
Check with different shops for price on full service. This is a great machine what ever they tell you.
Posted on Jan 09, 2010
SOURCE: Bernina Record 930 Electronic, seldom use, like
The manual for the Bernina 930 is online..Check out Bernina's site for it. Sounds like yours needs oiling. My handwheel was very hard to move and I finally oiled that and it loosened it up very well. I'm not sure when I had it repaired why that wasn't oiled as the rest of the machine had been. Great machine.
Posted on Feb 11, 2010
RickE1
  • 202 Answers
SOURCE: I need to replace the cam shaft gear on a Bernina
Hi, if you would like please email me at callnrick@yahoo.com and I can forward the technical manual of this and it that will walk you through it with pictures, etc. Also I can be reached at 612-801-6597.
Or just follow the directions and I can answer any problems via email. Its not hard.
Thanks.
Rick Engel
Posted on Sep 07, 2010
I have bernina 530-2 record and cant get it to start. nothing happens when I lift the knee control. Does this mean it needs a new motor?
Some of these old machines have carbon brushes in them. When it gets worn down from use and eventually fails to make contact, it will no longer work. The replacement carbon brush is relatively inexpensive ~$15.
Jan 23, 2017 | Bernina Sewing Machines
Where are the carbon brushes on a Bernina 830 Record 1970s sewing machine? In foot pedal or motor?
there are 2 in the motor ( normal electric motor positions )
there is a speed control attached to the top of the motor
Oct 22, 2016 | Bernina Sewing Machines
Purring sound on Bernina 530
If it is the new Bernina 530 computerized model, they do make a particular sound when started up. My 440 makes a peculiar sound at startup, but I've become used to it. I believe part of it is setting the machine to the default settings, ie positioning the needle, etc.
Sep 25, 2016 | Bernina Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
Bernina 530 I inherited a Bernina 530 Record and am trying to learn everything about it. How do I get it to stitch backwards?
Download a manual at Bernina.com, select Support, and go to Out of Print Manuals.
http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/BERNINA-manuals/BERNINA-Sewing-Systems
Jan 19, 2014 | Sewing Machines
I have just bought myself a very old unloved looking bernina record 530 for $5. Would love to clean it up and service it myself if u think this is possable...also it has knee control which is abit touch n...
Hi, I also have a 530 Record which has sewed an "illegal amount of km's!" Get a copy of the manual thru' the web, you won't find one for the 530 but the 530-2 & 532-2 manual will suit as they are very similar models. Make sure you oil it at designated places- too little AND too much both can give problems. Check condition of the belts. The machine should sew at a reasonable speed, if not or you think there's a problem with the knee-control, it could well be that the motor is on it's way out, (like mine). I'm trying to get mine rewired. Good luck & let us know how you go! Sam
May 20, 2010 | Bernina Activa 140
I have a Bernina 530 Record and i'm trying to but
You would be best to download an instruction manual for your machine as it explains clearly, with diagrams how to thread and insert the bobbin. You probably wont find the 530 manual however download a copy for Bernina 530-2 or 532-2 as they are almost identical to the 530.
Sep 25, 2009 | Bernina Sewing Machines
Bernina BERNETTE 65 Mechanical Sewing Machine Logo
409 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
