Question about Timex Expedition 40141 Wristwatch
Lost the operating instructions
4 knobs in addition to time knob. Help!
2 Suggested Answers
SOURCE: Lost knob
i need a knob for timex expedition!!!!!!!!!!!!!!!
Posted on Dec 21, 2007
I am looking for an instruction manual for a Structure watch 33415 model. There's an extra button or knob. What is it there for?
Fuzzy picture, but there are usually 4 buttons on a Sports Chronograph.
main knob pulls out and adjusts time, date and month depending on how far pulled out and which was turned.
one button is chrono start and stop
one button is split time
one button resets the dials back to zero.
I can't find a manual online
Dec 09, 2015 | Watches
Set up instructions
for a standard wristwatch
pull the knob on the right side out a little turn the knob which moves the hands on the watch, set to correct time and push the knob back in
Jun 19, 2015 | Watches
I've lost the owner's instructions and need directions for setting the alarm.
  • Unscrew the crown (the main knob on the center right side of the watch casing), wait until the second hand is at the 12 o'clock position, and pull the crown knob up so that it clicks once.
  • 2 Press the button below the crown knob repeatedly until the hands of the alarm dial point to the time within the next 12 hours that you want the alarm to ring. Pressing the button once will move the alarm one minute forward. Pressing and holding the button will move the alarm forward quickly.
  • 3 Pull the crown knob one click further out and turn to adjust the main hands to the correct time, to take into account the time you took to set the alarm.
  • 4 Push the crown knob two clicks back into its normal position, and screw it into place until it locks.
  • Aug 20, 2010 | Pulsar PXH225 Watch
    I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
    These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    How do you set the day of the week?
    Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
  • Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
  • Step 2 Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
  • Step 3 Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
  • Step 4 Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
  • Step 5 Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
  • It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
    Aug 11, 2010 | Watches
    I have a seiko chonograph couturo alarm. 100m
    Many of the Seiko Chronographs have the same setting options (mine is the lightweight "Titanium Sports").
    First off, the alarm dial must show the same time as the actual main dial. If not you must adjust this first.
    Pull the knob at number 4 position on the watch face out, until you feel two distinct notches/clicks (around 0.5mm travel) and the alarm will make a shrill buzzing for about 1 second.
    Now turn the #4 knob to move the small alarm dial at the #6, to be the same as the actual time displayed on the main face, and press the #4 knob fully back in. This sets the alarm and the main time to the same ....er....time. You do not need to do this again, unless you adjust for daylight saving times during summer/winter.
    Now you can set the alarm chime point.
    Pull the #4 knob out again, but just one click. You should hear one ping from the alarm. Now press the button at #8 position. It will move the small alarm hands by 1 minute intervals, and if you keep it held in, the dial spins around quickly. This allows you to adjust the time the alarm will chime.
    When you've got the alarm time and it's chime point set, leave the #4 knob at one click out.
    If you wish to switch the alarm off simply press the #4 knob back in, and the alarm dial will spin around to the same time as the main dial.To re-enable the alarm pull the #4 out one click again. It's quite simple once you get the hang of it.
    Jan 01, 2010 | Seiko Coutura Chronograph Watch
    I need to reset the hands
    Assuming you want to reset the zero posistion of the chronometer (stop watch) hands...
    On my watch I can adjust it by doing the following...
    To reset the microseconds hand / top right
    1) Pull the center knob full out (2 clicks)
    2) Press the bottom push button to adjust the hand
    To reset the seconds hand / middle
    1) Pull the center knob a full out (2 clicks)
    2) Press the top push button to adjust the hand
    To reset the minutes hand / top left
    1) Pull the center knob out half way (1 click)
    2) Next press the bottom push button to adjust the hand.
    Once all hands are reset, push the center knob back in fully...done
    Mar 16, 2009 | Swatch Irony watch
    How to set the alarm on a seiko presage chonograph?
    Try Googling (Seiko)(SUY055)(manual) without parens for instructions.
    Dec 15, 2017 | Seiko Presage SUY055 Wrist Watch
    Watch 3 dials inside face
    so its a chrono watch i belive. well sometimes diffrent models require diffrent operations to set up the display.
    Perhaps the manual can be found on the internet site of the watches brand.
    Mar 17, 2008 | Watches
    Lost knob
    Nov 27, 2007 | Timex Expedition 84601 Wristwatch
    Timex Expedition 40141 Wristwatch Logo
    85 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Brett Duxbury
    Brett Duxbury
    Vladimir Frolov
    Are you a Timex Watch Expert? Answer questions, earn points and help others
