Question about Tanaka 40cc Bicycle Handle Straight Shaft Trimmer/Brush Cutter
What causes a bush cutter to vibrate - Tanaka 40cc Bicycle Handle Straight Shaft Trimmer/Brush Cutter
  • 57 Answers
The vibration generally comes from the rotation of the motor, and the cutter head. The faster it spins the greater the vibration.
Cheers.
Posted on Jul 09, 2010
What causes vibration when turning in v70?
It could be Bushings or CV Axles causing your vibration. You can slide under the car try to turn the axles by hand with the tires on the ground. If the axles move at all they need to be replaced. Other than that a good alignment shop could tell you which bushings need to be replaced and what condition your tie rod ends and ball joints are in as these can also cause vibration.
May 21, 2014 | Volvo V70 Cars & Trucks
Can't find cutter. could it have fallen into machine. the clip that holds it is there. This happened after trying to clear a paper jam
Cutter unit having press & release system, by mistake its released, it might be fallen in paper bin.. You can see there is a cut at right side near blur lever,pull cutter bush up to there & load the cutter into cutter bush. Once hearing click sound manually confirm its fixed properly or not.. once its confirmed, push cutter in to park area, power on the printer..
Aug 01, 2012 | HP DesignJet 500 InkJet Printer
Hi,My Ryobi 30 Petrol with Brush Cutter attachment has so much vibration I cant use it..
This is likely a mechanical problem caused by either 1. A serious imbalance with the cutter attatched to it 2. The engine is failing and the main crankshaft bearings are worn causing crankshaft "wobble" setting up the heavy vibration you speak of.
Aug 29, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Acme juicer vibrating so much.
I've had one for 21 years and when I replaced the blade the same thing happened.
The blade is not supposed to be held firmly in place so it can slip intentionally to
minimize vibration. If you bought the juicer new, think back, and I believe you will
remember the vibration problem. I seems with a worn blade they vibrate less. The
motor is very durable and uses roller bearings like on a skate board. I went back
to the old blade, which I sharpen with a drill using a small bit.
Jan 11, 2010 | Acme 6001 Juice Extractor
2006 Pontiac G6 wheel vibration
Tie rod ends do not have bushings (ball and socket like your hip). If vibration begins at 50-55 but goes away at slightly higher speed, it could be caused by wheel balance. Once balance has been checked jack up each front wheel and shake them back and forth and check for any loose steering components. If reasonably tight, My guess is that you have a bad hub bearing. If you don't know how to change them, get a manual to guide you (chiltons or haynes are OK for this). Pretty much it is a bolt out bolt in procedure and not terribly difficult except that sometimes the hub is rusted in and is a bear to get out. Need any help with that, just ask.
Note...many bad hub bearings show no obvious defects...but can create a strong vibration...just determine which side is noisy and change it. Scrapyard parts are inexpensive and generally fairly reliable as replacements.
Sep 18, 2009 | 1995 Jeep Grand Cherokee
Same problem
Could be rust or brake dust on the rotors causing vibration. But check the suspension bushings as they could be the cause of the noise and vibration.
Jul 27, 2009 | 1998 Volvo S70
Front bushings
the control arm bushings on a 3 series are extremely important, when they completely fail they can cause your abs/dsc to activate when it's not necessary. also blown out control arm bushings will cause your tires to wear funny and the vehicle can have vibrations and steering issues. highly recommend replacing. a bmw dealership would provide a two year warranty on the parts and recommend an alignment.
Apr 20, 2009 | BMW 325 Cars & Trucks
Cutter Problem
the cutter has that bushing attached to act as a tire as it travels across the scan axis, these infrequently wear out and cause the carriage to basically drag the blade behind causing your uneven cut pattern, the cutter must be replaced. If you need direction on how to do so please contact me
Apr 16, 2008 | HP DesignJet 1050c InkJet Printer
Loose Cutter Block
when you remove the cutter block is there a white nylon fixture atop the vibrating mechanism? this nylon piece snaps on the vibrating rod and the cutter snaps into the nylon fixture.
Sep 02, 2007 | Braun Syncro 7526 Electric Shaver
Tanaka 40cc Bicycle Handle Straight Shaft Trimmer/Brush Cutter Logo
457 people viewed this question
Top Tanaka Cycling Experts
John Egan
John Egan
Are you a Tanaka Cycling Expert? Answer questions, earn points and help others
